Urgent advice needed from PriusChat - should I fill up or not?
Discussion in 'Gen 3 Prius Fuel Economy' started by Joe-G, Apr 29, 2013.
  1. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    Here is my scenario. I want to join the 500 mile tank club.
    I'm sitting at 470 miles, 32 miles from my favorite gas station or 1 mile from a station at work that is 30 cents higher. Between the two it's pretty much a bad area and I don't want to stop to fuel up. I also don't want to run out in this area.
    Thanks to a 180 mile AC trip with my larger buddies, I'm at 53.7 mpg indicated (down from 57 Friday!:() . DTE is 12 miles and the light started blinking with 20 miles DTE.
    Last time I filled up, it was with this tank, and I put in 9.559 gallons for 490 miles. The Cons gauge was 54 but actual mileage was 51.2 and DTE was 8.
    Think I can make it 32 miles?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Omg, just fill up. But that's coming from someone who never cared for this how far can I get out of a tank game.
    Now, if the light just started to blink 8 miles or so ago I think you should still have about 2 gallons in reserve so you should be able to make it. But let someone confirm that does this often or knows for certain 100%.
  3. wjtracy
    wjtracy Senior Member
    11,312
    3,588
    Northern VA (NoVA)
    I say fill-up because 500-miles on a Gen3 should be easy another day. But my understanding is Gen3 the EV battery will not take over when the gas tank is empty, so you probably don't have the risk of hurting the battery. In a Gen2, when the gas tank is empty the battery keeps moving the car until the EV battery is depleted, which is very bad for EV battery life.
    In a Gen2, I can approach 500 miles (480) only in summer when MPG is good and the bladder tank will accept more gasoline.
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    You'll make it, no problem.
    Be sure to write later to tell us if you made it. :)
  5. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    This is a sane response. ;)
    Let's see what others come in before I leave and have to make a decision.
  6. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I routinely went over 500 miles on my Prius IV so I'd say you can easily make it, but fill up if you have any angst about it. If it was up to me, I would decide to drive the 32 miles to save the 30 cents/gallon. I don't like paying more for something that I know costs less elsewhere.
  7. bisco
    48,945
    go for it! you've only used 9 gallons, there's plenty left. no need to worry at all. notch that 500 mile tank on your belt!;)
    Joe-G likes this.
  8. fuzzy1
    10,039
    My experience says that should be an easy cake walk. But I would never make a first test of it in a bad area where you don't want to run out. Test it first under benign circumstances, where the cost of failure is low and tolerable. My first car, many decades ago, would not have made it to the next station.
  9. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    ^^^ good responses guys, keep them coming.
    Is there another warning when it gets REALLY low on fuel, or is the blinking last segment of the gauge the only "low fuel" warning?
    On my Vette there is "Low Fuel" as a first warning, then, when fuel is really low it says "Reserve Fuel".
  10. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    No, you've gotten all the warning you're going to get.
  11. bisco
    48,945
    i don't think so. at least not on my 08, the last segment started blinking on my way to work. i figured i would fill up on the way home, forgot all about it and a few days later i ran out of gas.:eek:
  12. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Nope, you've been warned lol.
  13. WilMent
    WilMent diacritic
    369
    149
    New York
    Just fill up... I'm sure you saw the 800 or even 1000 mile clubs before. You will never stop at 500, besides it is not all that uncommon... not worth getting stuck on the side of the road. If you really have time to burn just find a loop and drive slow, it would only take you 20 hours or so to get unbelievable mileage. Do it next time after you buy a 1 gallon fuel container and keep it in the car....... common sense:eek: The container also helps you to FILL your tank without overflow.
  14. fuzzy1
    10,039
    The next warning comes after it is already out of fuel and the traction battery is essentially exhausted. It is not as 'friendly' as the Gen2, which warns before the traction battery is exhausted.
  15. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    This is a fantastic suggestion. Turns out we have a spare gas tank here at work.
    So I'm going to get a gallon at the station...and see how far my range is.
    Thanks for making that recommendation! Duh, what was I thinking.:)
  16. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    Glad you found a solution. But if you were stuck between achieving 500 miles and being stuck in a bad area, then just fill up. There's plenty of time for you to reach 500...First world problems :LOL:
  17. ETC(SS)
    6,492
    Good News: He didn't run out of gas.
    Bad News: The inside of his car now smells like a gas station.
    First of all....I have a work car that's a G3. I drive it like a rental car and the only way I can NOT get 500 miles out of a full tank of gas would involve a siphon, or lengthy idling. In other words....as the other posters have pointed out you still have the better part of two gallons of fuel remaining when you get the first (or the last) warning beep.
    If your tank average is anywhere above 45 you shouldn't have any problem seeing the (not so) magic 500 miles per tank.
    However (comma!) remember that we're also dealing with Priuses...Prius drivers..and basic human nature.
    Priuses have inaccurate fuel efficiency guestimations...at least my G3 does and I've heard a lot of other folks fuss and cuss about it too. Guess what? The MDF always gets it wrong in favor of the house (read: intentional bias)
    This means that unless Toyota has fixed this problem - you should always presume that your ACTUAL fuel efficiency is about 3-5 MPG less than it really is. Still.....if your tank MPG is notrh of 45? You can't help but get 500 miles out of a tank.....unless you leave the car booted up and go inside your house for a weekend or so. ;)
    OK...now we get to Prius DRIVERS and basic human nature.
    Priuses have a TWO GALLON reserve because the folks in Aichi Japan aren't morons!
    They know how we think.
    If I can get 500 miles out of THIS tank....then I can leg the next one out to 510.... ;)
    If Joey Bagadoughnuts can get 800 miles out of HIS tank...then why not me too?
    Basic human nature sometimes overrides common sense at times. That's why a the one gallon gas can that's rattling around in your car has to meet GOD knows how many federally mandated safety regulations and probably costs north of $15 when other containers are less than a buck.
    Whether or not it's wise to carry a filled one gallon container of fuel in your car?
    Your car....Your call.
    Me?
    I apply a -3 MPG bias to Goofy's fuel efficiency readout and get gas when I think that I can fit about 10-gallons exactly into the fuel tank plus or minus a gas station or two. At 46,000 miles...I've put more than 11 gallons in the car once when I wanted to make it to a better gas station.
    I'm an unofficial member of the 600 mile club, and I wouldn't want to deprive anyone that all too human joy of running out of gas trying to get to 800 or having a fuel can leak in your car!
    Just be careful...and have fun!
    Joe-G likes this.
  18. Chaloney
    Chaloney Junior Member
    Just filled up a few days ago a little shy of 500 miles, ~20 miles til "empty". Only put 9.1 gal in. Mfd said 57.1 mpg, calculated 53.3 mpg. Obviously I could have easily made it another 15 or 20 miles to 500. Probably could have made it to 600 miles. Just as obvious, the mfd reads about 5% higher than reality
  19. retired4999
    2,652
    625
    Eau Claire, Wi.
    Great old person's story!
  20. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    your car but sure you can make it IF it was real full tank at last fillup ! But my experience is when the car say 0 mile left you have at least 1 gallone more like 1.5 gallon left !!! I went 50 miles after 0 ...but your car your risk
