I can reset both batteries and the car runs fine for 10 miles or so. Then all dash lights come on, including the triangle, AC stops blowing cold air, and the fan motor located by the passenger rear seat comes on. I had the car 10 years and never heard that rear fan come on. Please help, Thanks.
You realise that when you "reset the batteries", it only gives the car amnesia until the fault reocurs, right? It does not fix any fault the car has. You need to read the codes (or have the codes read) that correspond to each indicator light and report them here to get advice that will help you.
