Urgent help needed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gio syl, Sep 20, 2021.
  1. Gio syl
    Gio syl Junior Member
    I'm having some issues with my battery pack
    So I replace all modules in my pack thinking that was the issue.....got the replace hybrid battery pack code
    When I tested the replaced cells came in at about 88%
    However after driving for about 4-5 days the replace hybrid battery pack code came back ....is it something defective on the battery pack component
    ....I was told that I have to replace the entire battery pack component .....
    Is there something bad such as a fuse that is causing the pack to drain rapidly
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Gotta make all modules same voltage
    51,996
    where did you get the modules?
