URGENT!! PLEASE HELP my prius gen 2 won’t start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TurkJohn, May 7, 2023.
Tags:
  1. TurkJohn
    TurkJohn New Member
    New York
    Hey Friends,
    I'm going on a long trip and I need my car, but my car is not working right now. please help me with this guys.
    While driving the car two days ago, the car started beeping and stalled (neutral). After that, when I stopped the car, I could not start my car again. I had my vehicle's 12V battery checked, but there is no problem with the current battery.
    I have the same problem as in the video I shared below, I searched a lot on the internet but couldn't find it. What do you think is the problem? This happened after driving about five miles after I had the brake pads changed.
  2. Tombukt2
    Tombukt2 Senior Member
    12,215
    2,155
    Durham NC
    You have codes you'll need to read the codes with a capable scanner to get the codes That's the first thing that needs to be done before you do all the button pushing and everything else If you push the button right now like you're going to start the car what lights remain after it does not ready so you don't see the green ready but you see traction control skid control ABS red triangle? Any of them take a picture maybe it's better.
    51,155
    beeping usually means brake actuator
  4. ChapmanF
    17,349
    There is a beeper for the brake system if the pressure gets too low to assist your braking. But it is not the only thing that beeps in the car, and I don't believe it prevents the car from starting.
    The Gen 2 repair manual probably has descriptions of the flash patterns seen here on the dash display and the power button, as well as for whatever trouble codes can be collected.
    Toyota Service Information and Where To Find It | PriusChat
  5. Trombone
    Trombone Active Member
    294
    101
    Allentown, Pennsylvania
    2002 Prius
    You've posted to the Generation 1 forum, and your question relates to Generation 2. Suggest you move to that forum for more replies.
