Urggg, he we go again :(
Discussion in 'Gen 4 Prius Main Forum' started by Chris Wolfgram, Sep 6, 2025 at 11:48 AM.
  1. Chris Wolfgram
    Chris Wolfgram Active Member
    415
    168
    Sacramento CA
    2019 Prius
    So WAY back, when my 22' Prius XLE was only 3 months old (May of 23') at which point the car had about 20K miles on it, I heard an audible 'beep'.... And suddenly, on my dash, I started getting all kinds of ominous warnings, like:
    Hybrid System Malfunction
    Low Braking Power
    Proximity sensor Malfunction
    Cruise control malfunction
    Please see dealer for maintenance
    ^ each for a couple seconds, as it just scrolled through these messages.
    Of course I did take it straight to the dealer. "they said" they ran all kinds of diagnostics on it, and:
    1) nothing was 'actually' wrong with the car, that these were all false signals, nothing to worry about.
    2) but now its not doing it. So if it happens again, just bring it back.
    Of course a couple days later, it did happen again, so I brought it back > to two different Toyota dealers "twice each" !
    Each time it was the same thing, they would mess with it for a bit, it would go away, and they couldn't get it to repeat the problem.
    So, I'd get it back, drive it for anywhere from a couple of days, to a week.... and 'Beep'.... here's all these false alarms again :(
    I guess I should mention, the one "actual problem" I do have when this is happening, is that I can't use cruise control, which freaking kills me, as I always use cruise control for multiple reasons.
    __________
    This ^ was all in May of 23'. Then, just about the time I was ready to give up on the Toyota dealers, it apparently fixed itself, and never did it again until 3 weeks ago.
    Then it started happening every 2 to 7 days...... Until 2 days ago, when it did it 3 X's in one day, and then 3 X's again yesterday ! So yes, it is absolutely getting worse :( But after my experience with the Toyota dealers two years ago, I can't even imagine dealing with all that again. I just have less than zero confidence in them.
    Now, I do Rideshare, and for obvious reasons, I can't have these messages, especially "Low Braking Power" popping up, and freaking out passengers...
    So, as goofy as this sounds, in the past, and I guess again starting today, I'm going to put a little piece of black card stock up on the dash, to block out the part with all the messages, and just deal with no cruise control :(
    Oh ! I know this is getting long, but I think this is pertinent too; I can make this quit happening 100% of the time, by simply powering down, and powering back up 4 X's, and on the 4th time > every time, it goes away ??? Maybe for 1 mile..... or maybe for a full week, and 700 miles ?
    I'm sure this was what was happening at the dealers too. They'd be messing around with, and the 4th time they powered it down, and back up, they'd be like, Look ! We fixed it.
    Gee thanks guys. Great job :(
    SOOO freaking frustrating. Any ideas ???
  2. Mendel Leisk
    40,870
    I vaguely remember your struggles. Lemon Law??
  3. Chris Wolfgram
    415
    168
    Sacramento CA
    2019 Prius
    Thank you Mendel. Yea, and ya know, I did actually call the Toyota Headquarters 2 yrs ago, and I asked them specifically > What happens if this same problem pops up 1 year, or 2 yrs down the road, when the car is no longer under warranty, and they said, all of my visits to the dealer, and that phone call to Toyota HQ were being recorded, and it it were the same problem that they never fixed the first time, it would still be covered.....
    However, during the time all this was happening, they noted that I had an aftermarket alarm, and stereo system in the car, and were trying to use that as a way to skirt out of any responsibility. So, before my 4th trip to the dealer, I actually had my stereo and alarm disconnected from the car completely, and it still screwed up. So, I'm confident that these items have nothing to do with the problem, but none the less, I can totally see Toyota using that as an excuse.
  4. Doug McC
    Doug McC Senior Member
    1,050
    401
    Midwest
    2022 Prius
    Just out of curiosity, do you get any diagnostic codes with the warnings?
    Chris Wolfgram and BiomedO1 like this.
  5. BiomedO1
    BiomedO1 Senior Member
    3,002
    1,609
    SacTown, Ca
    Yes, the actual diagnostic trouble codes would be more helpful; because we are just guessing at the problem.
    The low braking power, would be my main concern. Possibly a valve jamming up in your ABS system - that may disable your CC. If your braking system is compromised or the ECU thinks it's compromised; it's not going to let you activate it if "it can't pump the brakes". It's a safety thing.
    If the same error codes are popping up, I'd guess that whatever module it is intermittent or you may have mice chewing on your wiring harness. This would cause intermittent errors too.
    Hope this helps......
    Have you checked the 12V aux battery status? If it's below 11VDC, it can cause erroneous sensor readings.
    #5 BiomedO1, Sep 6, 2025 at 4:18 PM
    Chris Wolfgram likes this.
  6. Chris Wolfgram
    415
    168
    Sacramento CA
    2019 Prius
    Hey thank you guys.....
    But I might have a big break through !
    Look what I found online.... Funny thing is, I called Toyota and the receptionist (on a Saturday) told me that their were not any recalls on my car.
    Well, I'm going to be talking to the service manager on Monday, and if I need to, I'm going to walk in and show him these screen shots...
    OR, if I have to, I'll call and talk to Toyota HQ
    Screenshot_20250906-133413.png Screenshot_20250906-133400.png Screenshot_20250906-133313.png
  7. BiomedO1
    3,002
    1,609
    SacTown, Ca
    Use the attached link and punch in your VIN to see if your car is affected. Your car may already have the updated software installed.
    https://www.nhtsa.gov/vehicle/2022/TOYOTA/PRIUS/5%252520HB/FWD
