US Model: 05 DRL Relay & Fuse add on possible?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by martyoh, Sep 4, 2011.
  1. martyoh
    martyoh New Member
    Orange County, CA
    I apologize if this post is already been discussed before.
    I just got my 05 White Prius got many simple modes done like rear wiper and wheel cover removed thanks to priuschat forum.
    I want to explore if there is way to simply add DRL by adding a relay and a 15amp fuse. I took 3 pictures to illustrate my point of view.
    It looks like relay and 15amp is missing from US model?
    Would be easy as just adding relay and a 15amp fuse?
    Anyone explore this mod yet?
  2. RIGOBERTO
    RIGOBERTO New Member
    CDMX, MEXICO
    HOLA, TENGO LA MISMA IDEA QUE TU Y CREO QUE SOLO ES CUESTION DE ALGUN RELE Y FUSIBLES QUE SE PONEN Y FUNCIONA, OBVIO FALTARIA CONSEGUIRLOS, PERO SABER QUE SOLO ES ESO SERIA DE GRAN AYUDA, ANEXO IMAGENES DE LOS FUSIBLES EN MEXICO DONDE NO ENCIENDE LA LUZ TRASERA CENTRAL DIURNA, ESPERO ALGUIEN DE USA U OTRO PAIS DONDE SI FUNCIONA COOPERE CON FOTOS DE SU SISTEMA DE FUSIBLES EN CAPO Y EN CABINA PARA DETERMINAR Y ENCONTRAR LA SOLUCION AL "PROBLEMA", MI MODELO ES PRIUS PRIME 2023 VERSION MEXICO
  3. dolj
    dolj Senior Member
    7,627
    3,848
    Wellington, New Zealand
    Debes hacer tu pregunta en el foro correcto. Has publicado en un hilo del foro Gen 2. Debes iniciar tu propio hilo en un foro de Prius Prime y hacer tus preguntas allí.
    También necesitas actualizar tu perfil. Si se tiene un Prius Prime, no es 'Otro Híbrido'.
    Mis mejores deseos.
