Usage of Fuel Injector Cleaners
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sumedha, Apr 16, 2015.
  1. Sumedha
    Sumedha Junior Member
    52
    Colombo, Sri Lanka
  2. qdllc
    qdllc Senior Member
    1,370
    399
    I just run B-12 Chemtool through every 10,000 miles. Fuel-system-safe solvent. Used it for years.
  3. Sumedha
    52
    Colombo, Sri Lanka
  4. qdllc
    qdllc Senior Member
    1,370
    399
  5. Okinawa
    Okinawa Senior Member
    1,333
    317
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Typically you can't ship things like that through "normal" channels; Hazardous contents.
  7. Okinawa
    1,333
    317
    You are right. I failed to notice he was overseas.
  8. Easy Rider 2
    1,584
    257
    Ocala, FL
    You are not supposed to ship them inside the US either.
  9. ChapmanF
    15,585
    As far as documented "PriusChat Experiments" go, PC member astrolink had a very rough-running car that was cured with off-car restored injectors, but had not been cured by his earlier attempts with an injector cleaner fuel-tank additive. The test results for his original injectors before and after restoration are here. They clearly show the injectors were in bad condition as removed from the car, even after the attempts with the fuel-tank additive.
    I don't think he said what additive he tried, probably not the same one you've asked about.
    An article in Import Tuner seemed to reach the same conclusion: in-tank additives might not be up to the job, at least if the injectors are already bad enough to be a problem. (I guess that doesn't rule out that they might help keep the injectors from getting that way in the first place, but doesn't prove it either.) The off-car process seems to bring them back to spec with no problem.
    What that doesn't address is the chance that the tank additives also clean other areas like the valves and combustion chambers, which of course the off-car process can't do because it's off the car.
    So from what we've seen so far, it might be safe to say the tank additives don't seem to do harm, may possibly do some amount of preventive good, but might be too little too late if the injectors are already thought to be bad.
    -Chap
