USB player locks up - how to unlock?
Discussion in 'Prius c Audio and Electronics' started by Alan Lau, Oct 27, 2014.
  1. Alan Lau
    Alan Lau Junior Member
    Windsor, CT
    2014 Prius c
    Sometime while playing music on a thumb drive, the song will stop playing, and even though I can browse to another song, it won't let me switch songs. The only thing that helps is to turn off the car, then turn it back on. This is not a good solution if one is driving on the highway. I've tried unplugging and re-plugging in the thumb drive, switching to radio and back to USB, but this does not help. I've tried turning the audio off, then back on, does not help. Is there a way to re-boot the audio unit without turning the car off and on?
  2. JC91006
    16,827
    8,600
    try a different thumb drive and see if it does the same thing.
  3. Alan Lau
    Windsor, CT
    2014 Prius c
    It's not thumbdrive specific. And any song that locks up the player will play just fine once the player has been rebooted.
  4. JC91006
    16,827
    8,600
    you've tried a different thumbdrive and same thing happens?
  5. bisco
    52,351
    try a memory stick, i don't have any issues.
  6. Alan Lau
    Windsor, CT
    2014 Prius c
    thumb drive = flash drive = usb drive = jump drive = memory stick
    Ronan likes this.
  7. Alan Lau
    Windsor, CT
    2014 Prius c
    I'm on my second thumbdrive. The problem is intermittent. It will work fine for weeks then 1 day it will crash twice in the same day. At that point I usually switch to FM or Bluetooth until the next time I start my car.
    I just wish there was a way to reboot the radio that did not require me to shut the whole car off.
  8. JC91006
    16,827
    8,600
    Try putting less songs on the drive and have multiple drives to store all your music. I would say your experience is quite normal, my drives also crashes at times. It's not all that great.
    #8 JC91006, Nov 5, 2014
  9. bill03060
    bill03060 Junior Member
    Nashua, NH USA
    2022 Prius
    XLE AWD-e
    Plug it into a Windows system and select Properties, then Tools. Click on the Error Checking and run a scan. The Prius entertainment center appears to write to the USB drive. I see Playlists with $$ characters in them, which I did not put there. So, it maybe corrupting the file system when you shut the car off while it is playing.
  10. GregP507
    GregP507 Senior Member
    3,002
    481
    My problems were solved when I switched to another flash-drive.
  11. Richard Jones
    Richard Jones New Member
    NY
    I had a similar problem, you can probably fix it by getting a new flash drive.. Seems to be a common issue.
  12. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    If you conclude that you may have a faulty drive, try a San Disk Cruzer Fit CZ33. Amazon has them
    Nice and compact, too.
    Have been using one for 2 1/2 years with zero problems.
    #12 rjdriver, Nov 19, 2014
    ztanos likes this.
  13. Bret Carlin
    Bret Carlin New Member
    Raleigh, NC
    I have found on my Prius C 3 that if I reinstall the latest entune firmware from a thumb drive, it behaves for awhile.
  14. mpheinitz
    mpheinitz Junior Member
    San Diego
