USB Port won't recognize MP3 Player
Discussion in 'Gen 3 Prius Audio and Electronics' started by detroitandroid, Sep 13, 2009.
  1. detroitandroid
    detroitandroid New Member
    Napa, CA
    I have a brand new (purchased two weeks ago) Prius IV that came pre-equipped with a USB port in the front seat arm rest. I've tried both my iPod mini and Blackberry Storm and the Navigation system doesn't recognize either device. The USB tab stays greyed out. In addition, both devices show that they are charging when I plug into the USB port. However, the iPod shows the do not disconnect message so I can't select songs to play. I've heard other cars with this type of problem you need to install some sort of exe (firmware update) from a thumb drive to fix. Any thoughts on how to rectify this?
    Thanks.
    detroitandroid
  2. alanmo
    alanmo New Member
    Santa Monica
    I am having this same problem and it is very frustrating. If someone knows how this can be fixed, please let us know.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Is the vehicle moving or stationary at the time?
    Tom
  4. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Look at the DVD or the Sat Radio tabs with the iPod attached. You may see the iPod content displayed, but it may take 30 sec or do the first time.
  5. pro101
    pro101 The best car, is no car.
    Seattle WA
    I just got a IV with a USB port, and have a 80GB IPOD (original, 5th generation I think). I plugged it in while the car was off. Turned on the car, went through the touchscreen (Navigation) interface to the tab called "USB". It recognized it without any problem. Try this, you may also update your Ipod firmware to the latest through itunes and double check your connector cable.
    I hope it works for you.
  6. reverai
    reverai New Member
    119
    Alexandria, VA
    It does seem there are some Prius 2010 that seem to some issues and others that work fine. I have a friend who has the USB in her Prius and it worked fine with a first generation Itouch and a second generation Nano. The interface is rather clunky but it worked. Perhaps, a visit to a toyota dealer might clear this up the problem.
    Steve
