Use non-TPMS 15" wheels on Gen III?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jimbobx, Mar 15, 2014.
  1. jimbobx
    jimbobx New Member
    Apologies if this has been treated -- I didn't find anything thru "Search"
    I have non-TPMS 15" steel wheels with snow tires mounted. If I buy a 2013 or 2014 Prius with 15"
    wheels, can I continue to use the old snows?
    Thanks, jim
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Yes, you will just have to ignore the TPMS warning light on the dashboard. ;)
    SCH-I535
  3. Bingee
    Bingee Member
    210
    62
    Michigan
    A little black electric tape , over the TPMS yellow warning, and no little warning , unless your state has vehicle inspections , then ??
  4. James Mercer
    James Mercer Junior Member
    Nebraska
    Does the lack on tpms on snow tires affect any other systems in the vehicle?
  5. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    No, it is simply there to let you know when a tire is low on air pressure
    I have gone through two winters here in tropical Buffalo NY with no TPMS snows.
  6. James Mercer
    Nebraska
    Thanks. Does the tpms reset automatically when you reinstall the factory rims? My Fit did. I trying to decide between dedicated snow tires or a better all season LRR tire. We don't get the same volume of snow on the prairie as you do in Tropical Buffalo :)
  7. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
    Yes your all set when you refit your summer wheels .
    I have been very happy with my Michelin Ice dedicated snows, the mpg hit is ~ 2 mpg (I run them 42psi front, 40 rear)
    If I am not mistaken my car actually picks up the tpms signal from the tires stored in the rafters overhead in my garage and doesn't give me a tpms error for 20 minutes or so during the winter.
  8. James Mercer
    Nebraska
    Thanks for the info. I think I'll go the snow tire route.
