Used auxilary battery
Discussion in 'Gen 2 Prius Main Forum' started by abador, Dec 5, 2019.
  1. abador
    abador New Member
    Michigan
    I recently replaced my auxiliary battery after the self diagnostics seemed to indicate that is was bad and after it was tested by an auto parts store without removing it from the car. I learned after this that it needs to be removed from the car to be tested accurately. When I brought the old battery in to get the core charge back (I had already installed the new battery at this point) I had them test it just to make certain that it was bad. It ended up testing at 100% and it looks like I am not able to return the new one for a refund. Is there a market out there for used auxiliary batteries? I know new, they are around $200. Any idea how much they would go for?
  2. jayblue2301
    jayblue2301 New Member
    NC
    whats the date on the old battery? i might be interested in buying it
  3. Mendel Leisk
    38,652
    I don't this is true. I test with a Solar BA5, battery connected to the car, no problems. The only stipulation is that the tester clamps go directly to the battery posts.
    I'm sceptical. How old was it? If 4~5 years, I wouldn't pursue this.
    49,393
    i would be interested to know how old it is, what machine they used to test it, and the test results
