Used Prius that sat for 6 months, any concerns
Discussion in 'Gen 3 Prius Main Forum' started by insane_irish, May 2, 2016.
  1. insane_irish
    insane_irish New Member
    United States
    Recently purchased a used 2012 Prius that appears to have basically sat on the dealers lot for close to 6 months. This being my first Prius, I'm not certain if the depletion and recharge/regen rate of the battery is within norms. I'm wondering if I should have any concerns, and if there are any tests that can/should be done to confirm the battery/systems are operating as expected.
    Thanks!
    alanclarkeau likes this.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The big battery should be fine, the small 12 volt battery may well be dead.
    48,990
    welcome and congrats! none at all. if it's running fine and your mpg's are good, i'm sure it's in good shape. all the best!(y)
  4. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    That's much the same story as my 2011, which similarly "sat on the dealer's lot" for 4 mostly summer months before I bought it used, by then about 3½ years old. After I took it on a test drive with the salesman and drove it home (thereby recharging the battery a little) the original 12v, was at about 11.95 volts. Subsequent longer trips brought it back up near normal, but I replaced it 5 months later, possibly prematurely. The big battery was, as far as I know, OK.
  5. insane_irish
    United States
    Great, thanks for the info guys. I haven't measured the 12V, but haven't had any problems with it. The big battery I guess is operating fine, just seems to discharge faster that I expect at times and I have yet to see it reach full capacity. I've averaged a few tenths over 50mpg since I've had it and a large percentage of my driving is highway (although with traffic some days it probably gets somewhat closer to a 50/50 ratio) which I gather is pretty normal.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    United States is some what vague, but unless it is mountainous there (Smokies, Rockies, Sierra, Cascades) you will not fill the big battery. The computers always try to leave some room for regenerative braking, it will take a big downhill (1000 foot drop) to fill it. Then as you level out it will go back to 6 bars as soon as it can.
    CR94 likes this.
  7. Mendel Leisk
    38,247
    We purchased a 2010 "new" in November 2010, with about 10 km on the odometer. It was dusty when we spotted it, at the back of a warehouse on dealer's lot. The 12 volt was completely dead, dealer replaced without quibbling.
    We bought it, and it was only later I noticed from the driver's door jamb decal: build date was August 2009. So about 15 months it had sat.
    Anyway, 5 1/2 years later, still champion, no problems.
    BethPet and ovianc like this.
  8. insane_irish
    United States
    lol, yeah, no mountains around here, so that is good information to know. I've seen/gotten it as full as -1 bar (can't remember how many bars there are total atm).
  9. insane_irish
    United States
    Great to hear!
  10. bisco
    48,990
    many noobies think the battery charge indicator is telling them there's a problem, because they expect the battery to empty out and fill up. but that's not how it's programmed. it usually sits near the middle, and only at the top or bottom under exceptional conditions.
  11. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    I agree mostly, but there are also plenty of places in the East where you can fill up the state-of-charge display. We could salvage more of that potential energy if there were a way to advise the computer to "go ahead and use up some charge, because we're about to descend a big hill." Instead, it stays stuck at its usual 6 (of its 8) segments all the way to the beginning of the descent.
  12. jeff652
    jeff652 Senior Member
    597
    623
    Idaho
    If the battery is draining/filling rapidly, or re-calibrating, then a preventative maintenance reconditioning should be performed. Draining/filling rapidly, or re-calibrating are signs of cell imbalance that will get worse if not attended to. You can read more about this phenomenon here:
    What causes hybrid batteries to degrade and fail? - Hybrid Automotive
  13. bisco
    48,990
    how many miles on her?
  14. insane_irish
    United States
    How does one define "rapidly" with regard to draining and filling though, that is what is unclear to me. I will read the linked info later this evening, Thanks!
  15. insane_irish
    United States
    45xxx
  16. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It is very hard to recommend some one near by to United States, your location defeats real help.
    if I pull into McDonalds and order, then creep around the building, the engine starts to recharge about the time I get my meal. But I run headlights 24/7 and am running A/C all year and so on and so on. it is hard to make a hard and fast rule. I can often stay in EV for a mile after coming off the highway for at least 20 miles.
  17. bisco
    48,990
    rapidly is defined as going up and down without spending any time in the middle. you'll know it if you see it, but you won't see it at 45,000 miles. don't let your imagination run away with you.:)
  18. insane_irish
    United States
    Good deal. Thanks!
  19. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Because the "traction battery" is used to propel the car, and because it is rather low capacity (6.8 A-Hrs) it will vary in charge a lot. Don't get me wrong, there's a lot of power in it, but to run the car, it takes a lot more.
    It's best not to discharge it low and recharge it high a lot. Best for longevity. The HSD programmers know this, and therefore it only operates over a limited range (30% to 80% charge). You will see that as zero bars to full bars.
    It's "smart", so relax and watch the blinking display. ;)
