Used Prius v what to check ?
Discussion in 'Prius v Main Forum' started by Uyghur, Feb 23, 2016.
  1. Uyghur
    Uyghur Junior Member
    Bergen,Norway
    I am new to the form. Planning to buy used Prius plus(This is what it is called here in Norway), wondering if there is anything special I have to keep my eye on. Recently I just found very nice example which is used as taxi. 2012 module, it is premium line (equal to US Prius v 5 I think). I would like to add the link, but I was not allowed to do it as a new member.
    Car has 200,000 KM on odometer, has full service history, everything works just as it is according to delar.
    My question is, are there anything special that I have to check ? or look carefully ?
    Is this hight mileage going to be problem ? asking price is close to 16300 USD.
    All advice will be appreciated !
    Thanks !
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,980
    4,724
    Texas Hill Country
    I would think twice for that price and mileage, but our US used car market may be lower than yours. The inverters have failed on some of these models, although a recent software update has been offered by Toyota to hopefully avoid overstressing that component. The HV battery is a concern as would be any mechanical problem on this relatively complex car. If it were here, I would look for something in the 100,000 km range for that money or buy a new one for less than $10,000 more.
    49,506
    i would also be concerned about taxi use, if they drive like they do over here.
  4. Uyghur
    Bergen,Norway
    Thanks for the advice, cars are expensive here(ridiculously), brand new top model costs close to 52000 USD. I have asked for technical check at Norwegian Automobile Federation, which offerers independent check on all components. Will also have to check with toyota that if the car has Hybrid Battery Extended Care(if you keep doing service at toyota, they will extend warranty for hybird battery 1 year every time you do it).
    So if all those looks ok, will it be good buy ? I mean in that case I will have warranty on battery for 1 year, if I keep doing service at Toyota it will be extended.
    Just uploaded some pictures from dealer.
    BTW: car is registered December 17th 2012, so it is actually 2013 module.
    Other then battery, anything else to look at ?
    27_2025513556.jpg 27_1843602763.jpg 27_1775731621.jpg 27_1323916100.jpg 27_1296414572.jpg 27_1258825412.jpg 27_1234618584.jpg
    Thanks ! .
  5. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Damn that's a clean car for having 200,000 clicks on it!
    alanclarkeau and ahmad ashfaq like this.
  6. Uyghur
    Bergen,Norway
    Yes, Thats why I am quite interested in this car :)
  7. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Have the 12v battery tested and or replaced depending when that was last done. Check the tire depth remaining, and alignment. See if the veh. Maintenance history will be provided or at least oil change history... Was it serviced at the dealer, and if so they might have the printout of the veh history, but if it was a taxi maybe not.
    It seems most well maintained 3rd gen Prius are getting 200k+/- Miles out of the HV Battery, so you should be good for a while at least hopefully since yours would be at 200k km which is roughly 125k Miles...but if you plan on keeping the car pls plan accordingly and budget for a new HV battery eventually.
    Oh, and meant to ask, solar roof? Or wrapped? Looks awesome!!
  8. Uyghur
    Bergen,Norway
    Him
    Thanks for your advice. Car is used as taxi from 17 Dec 2012 until now, it is serviced at the dealer all the time. As I said in that case I will always have one year extended battery(Hybird) warranty until that car gets 10 years old(that is if I keep doing maintenance at dealer).
    My concern is more on the other mechanical parts, like engine and gear box , specially gear box, if there is any reported example of failing gear box ? or even engine ?
    It has dual solar roof yes. here is more pic's.
    27_2025513556.jpg 27_1553836428.jpg 27_1047805990.jpg 27_737152208.jpg 27_689575882.jpg 27_610522674.jpg 27_449321291.jpg 27_179976160.jpg 27_9350732.jpg
    Thanks !
  9. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    There are no gears, transmission is CVT, so no real worries there. And it's a hybrid so the engine is never really stressed too hard since well pretty much half the time the engine is not running and you can't blow the engine since redline is restricted to a certain safe rpm.
    Prius are solid and very reliable cars. Do the basic maintenance and your golden.
    Others will probably chime in and advse on a few other things to check and what's needed maintenance wise on a higher mileage Prius...
    GregC1979 likes this.
  10. Uyghur
    Bergen,Norway
    Thank you , that makes me more confident on this Prius:) waiting for the check reports to come, if there is no big problems, I think i will just buy it :)
    Blizzard_Persona likes this.
  11. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    I would replace the 12v battery if its still the original. Don't wait for it to die, which it will surely do.
  12. Uyghur
    Bergen,Norway
    Thank you ! I will definitely change it.
  13. mikefocke
    3,701
    1,649
    Sanford, NC
    I recall being in Scandinavia and hearing the taxes on new vehicles and being astounded. So any comparison of your prices to our prices is useless.
    Maintenance history? Look at the major services. Were things specified in the major services listed as done?
    Have the rotors and brake pads thicknesses measured. Taxi use can be rough on them. While Prius vehicles are gentle on brakes, they can still wear and you will want to know what the state of yours are to know when you'll have to replace them. Any history of brake fluid replacement?
    Date on sidewalls of tires? Tread depth in 3 places (left, right, center) in tread of tires?
    v's are reliable. But any car 4 years old and 200km can have problems.
  14. Uyghur
    Bergen,Norway
    mikefocke: Thanks for your advice. Unfortunately somebody offered better price to the dealer, so car was sold before I mange to get technical test reports. As all you mentioned about service history, when I checked it, It was not as satisfactory as I was expected, It was missing couple of services which made me hesitate to make final decision. Anyway it was sold, But I found an other example which is as nice as that white one but with more detailed service history. And dealer is asking for almost same price, I ordered technical check again on this one, if technical report comes good, I will just buy it I think. Here are some pics. 95_1589219196.jpg 95_1455946833.jpg 95_1393221339.jpg 95_1370037681.jpg 95_764568601.jpg 95_690422372.jpg 95_573628632.jpg 95_508977959.jpg 95_322222589.jpg 95_214535059.jpg 95_121840300.jpg 95_65247539.jpg
    This one is missing front parking sensor (extra one) compare to that white one, but it has nice and clean service history from Toyota. Hybrid battery has one year extended warranty until 01/sep/2016.
    This should be a good buy right ? :)
  15. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Did you buy it?
  16. Uyghur
    Bergen,Norway
    Blizzard_Persona, I didn't. I was out traveling for month, cat one was sold as well.
    I am back to the track and hunting Prius plus again :)
  17. jpto
    jpto Junior Member
    I'd suggest you get a newer than 2012 prius v - solely for the traction control defeat button (not sure what year it was introduced but the 2012 models don't have them) I'm assuming Norwegian winters are worse than Canadian winters and there have been occasions where I wish I could get a little bit more wheel spin before traction control shuts the power off.
    Before people ask - yes I've got winter tires & yes I know how to drive in the snow - last car was a two seater rear wheel drive car with less ground clearance than the prius and IMO it was better in the snow.
  18. Synthetic
    Synthetic Junior Member
    35
    El Paso
    Texas, USA recent purchase: 2012 v 5, 115,000 miles, silver/ash, mint interior, a few leading edge chips, one body penetration ($90 repair), and near new Hankook tires, from a Toyota dealer, $11,700 including the dealership $199 doc fee. We looked quite a bit over a month or so and this one was about the lowest list price for mileage and condition. I did need to fly to get it and drive home, another $600 or so. Your cost at list price over there would buy a 2013 v 5 with about 50,000 miles on it over here. But, you get to live in Norway.
