Used Prius with no servicing till 40k?
Discussion in 'Gen 3 Prius Main Forum' started by Mayank Jain, Feb 20, 2018.
  1. Mayank Jain
    Mayank Jain Member
    99
    70
    Cupertino, CA
    Hi Prius Chat,
    I came wandering around, looking for information - and I fell in love with this community. So vibrant!
    Please keep it up.
    I am a first time car buyer (new to US too). So please excuse the naive nature of my question.
    I've been researching on used Prius and came across many used cars in which Carfax shows no servicing till about 40k mileage. I am assuming these were rental/fleet cars.
    Question
    - How important is for a car to get serviced in those initial 40k miles? (ignore the rental bit for a sec)
    - If a 3rd party mechanic were to inspect (and okay) such a car, is it safe to move forward with?
    Thanks!
  2. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Even if a third mechanic were to certify it OK, I'd as a matter of urgency replace the engine oil, and check if the inverter and engine coolants are OK, leave those alone.
    We don't know theileage on the car yet.
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    If servicing (mainly oil/filter changes & tire rotation) were performed my the owner or an independent mechanic rather than a dealer then Carfax would have no record.
    It might be worth checking the VIN for recalls that need to be performed though.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The odd part is that by 2012, the Prius had free service for the first 25,000 miles. You would think that they would do "free".
  5. Prodigyplace
    11,696
    11,318
    Central Virginia
    That depends. I took my 2017 in for the 5000 mile tire rotation & check. Based on that poorly documented experience, I chose to do the oil & filter change myself. If they lie about the tire pressures set (32 vs 39), can they be trusted with an oil change? They also said they did not check the battery because the Prius is different. Gen 4 (2016 & later) Liftbacks have the 12 volt battery under the hood like most other Toyotas.
    Montgomery and Raytheeagle like this.
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    If oil and filter change (and tire rotation) are not considered service then fine. Prius is a Toyota. It doesn't need fixing monthly. If it didn't get an oil and filter change for 40,000 mi run away screaming! A mechanic won't be able to tell if no oil change caused damage, until it fails.
    Pull the dipstick and look at the oil on it (if any). I've personally never left oil in that long but I'm told it will be black. If it's clear or honey coloured they did the oil and filter themselves and it's probably ok.
  7. BZzap!
    BZzap! Senior Member
    1,607
    877
    I would run the V.I.N. through the Toyota Owners web sight and see if you can retrieve any service information. Also, consider that the vehicle had 2 years of free services. Someone had to reset the maintenance flag every 5 thousand miles. It’s unlikely that this was done without an accompanied service.
    Prodigyplace likes this.
  8. Mendel Leisk
    38,710
    It's very likely (well hopefully) a case of maintenance done "under the radar". That's our car: if you look on the Toyota website, it's a basket case, only been in for a few recall items. The reality: I've DIY'd all the maintenance.
    DLC82SV, mygel and padroo like this.
  9. bisco
    49,447
    welcome!
    could be some lazy owners here and there who figure oil changes aren't worth the time if they are busy. not going to effect anything in the short run, but i'm not qualified to judge the long run in that scenario.
    it would seem that the most amount of wear would occur in a new engine, causing more debris in the oil, but i have no idea.
  10. Mendel Leisk
    38,710
    I'm more inclined to cast a dour eye on solely dealership serviced cars...
    mygel, kc5dlo, scona and 2 others like this.
  11. bisco
    49,447
    do you think they would say they changed the oil, but didn't? or maybe not change the filter? or forget to tighten the drain plug? or overfill by a quart every time?:whistle:
  12. Mendel Leisk
    38,710
    Yeah there's been a few horror stories here. There's pros and cons I guess. My main take away: you can't put too much weight on dealership maintenance record, could be good, or no.
    scona and Prodigyplace like this.
  13. Mendel Leisk
    38,710
    Dealership serviced cars tend to have this bit broken off, or nearly so:
    Plus broken/missing fasteners.
    kc5dlo, scona, Raytheeagle and 3 others like this.
  14. BZzap!
    1,607
    877
    You would think that being a relatively new car( low mileage), the previous owner/owners would have done their due diligence. It’s hard to say but I would be inclined to say that they did. Don’t get me wrong. There are fools out there that are incapable of even checking their own oil, let alone changing it. However, as I said, “ Someone had to reset the Maintenance flag”, either because of an annoyance or due diligence oil changes. Would I buy such a car? Sure...especially if CarMax sold it at a reasonable price and an extended drivetrain warranty was negotiated.
  15. MelonPrius
    MelonPrius Senior Member
    821
    509
    Las Vegas
    I purchased my Prius with 29k miles. I looked up the maintenance and nothing was listed. I asked the owner and he said, "Maintenance? What maintenance? I changed the oil twice and it's due for another change now. That's why the maintenance minder comes on when you start the car. "
    He had a point. As per the maintenance guide, there's not much to do even at 40k miles ( oil changes, rotate tires and check fluid levels, while changing air filters when necessary). So, I just followed the maintenance schedule and it was easy, even for a novice like myself. I have the transaxle fluid on my tdl, based on advice here, but haven't gotten around to it.
  16. Mendel Leisk
    38,710
    A full brake inspection is on the US schedule, every 30K miles or 3 years.
  17. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Bought mine at 40K, the carfax indicated that the oil was serviced every 10K. Had no problems now at 119K. Getting ready for some serious DIY maintenance at 120K.:eek:
  18. Mayank Jain
    Mayank Jain Member
    99
    70
    Cupertino, CA
    Thank you everyone for sharing your nuggets.
    Since I am a first time car owner myself, I am not sure if I can do a really good job at DIY stuff in my 1st year.
    I am now inclined more towards buying well serviced cars (specially because there are so many of them available) in the same price range.
    This community is awesome. Thanks!
    Prodigyplace and Mendel Leisk like this.
  19. MilkyWay
    MilkyWay Active Member
    819
    357
    23
    MI
    It is not important at all whatsoever. These go to about 500K miles in many cases with original parts!
    The only way it shows up on carfax is if it goes in to the Toyota dealership or another large shop that enters it into the carfax system.
    There really isn't much to do besides maybe tires in the first 40k miles.
  20. Prodigyplace
    11,696
    11,318
    Central Virginia
    Oil & filter changes are important too. but they were likely done if the oil looks good.
