Useful app to help extend life of battery packs.
Discussion in 'Gen 2 Prius Main Forum' started by kens97uber171, Aug 24, 2018.
  1. kens97uber171
    kens97uber171 Active Member
    177
    132
    US
    I came across this app recently. It connects with any Bluetooth OBD2 device.
    And get you some nice control over some functions.
    Called "Hybrid Assistant" and it works on other generation of Prius and other Hybrid models also.
    You can set min and maximum temps on the Hybrid pack that triggers the fan to ramp up to full speed. Has some other useful info.. temps on engine, inverter, MG1, MG2..
    I live in a very sunny, hot dry climate . And the inside of your car can get very very hot...
    Heat is the killer of batterys.. so this app may help you out if you have a pack that's a bit old and extra sensitive.. or your getting a thermal warning..
    I'm using an Android phone, not sure about iPhone support.
    The only issue I've had is that it does NOT seem to get the MPG correct.. it's WAY off.. and I'm not sure why.
    They have a support contact.. and they did respond to my inquiry very quickly.. asked me to send a log. I did . They suggested some changes in the settings. That made no different.
    I suspect it's trying to display L/100klm or some other Euro output.. or it's miscalculation on the app.
    But it's very useful for the battery temp..control and monitoring other temps and outputs.
    And it can be set to automatically reconnect and start when the car does. I've not seen it cause any later in my phone either while connected or when sitting in waiting.
    Hybrid Assistant - Apps on Google Play
    20180824_152359.jpeg 20180824_152417.jpeg 20180824_152429.jpeg 20180824_152441.jpeg 20180824_152453.jpeg 20180824_152716.jpeg
    PriusCamper and nssdiver like this.
  2. PAUL SCHULTZ
    PAUL SCHULTZ Member
    103
    66
    Michigan
    HA is a known app on PriusChat. It does have many useful features. Be forewarned that if you run it during every drive, every day for a while it can lead to some screen ghosting/burn-in. Don't ask how I know that.
    In the end, I was running it for no real benefit other than "info overload". It does give some nice data though especially if used with its companion app, Hybrid Reporter.
    Paul
  3. BuickGN
    BuickGN Junior Member
    25
    48
    Los Osos
    I would love something like that. Just looked in the Apple store, didn't find it but found a couple others with some potential. I need to get engine sump and inverter/transmission temps (the motors would be a nice bonus) because with my very hot climate and long commute under heavy load, I want to upgrade the inverter heat exchanger sooner rather than later if it looks like it would be beneficial. This would be exactly what I need for recording data. I guess I need to look into some sort of Bluetooth/OBD interface???
  4. PriusCamper
    PriusCamper Senior Member
    11,068
    4,506
    Pacific Northwest, USA
    Thanks for the report and screen shots...
  5. kenoarto
    kenoarto Senior Member
    396
    Chicago, IL
    I can not get this app to connect. All the other apps work fine for me.
  6. kens97uber171
    177
    132
    US
    Weird. It linked right up for me. You may have to fair your Bluetooth OBD2 adapter to the phone first.
    Mine automatically reconnect to the car cery fast. 99.9% of the time.. usually it's the BT adapter that's needs a reboot when it fails to initiate.
  7. kenoarto
    396
    Chicago, IL
    My other apps use the same OBD2 adapter and work fine.
  8. PriusCamper
    11,068
    4,506
    There's so many cheap knock off OBD2 devices and the good ones are similar in price to the garbage ones. Here's only article I've found thus far that tries to out the bad ones: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    kens97uber171 likes this.
  9. kenoarto
    396
    Chicago, IL
    I didn't pay much for mine, but the question remains: why does my cheapo work with all the other Prius apps, but not this one?
  10. PriusCamper
    11,068
    4,506
    I've already got my money back for the past two cheap ones I bought (why I like ebay) because they couldn't read anything other than most basic info... Catch is the truly good ones at times are only a few bucks more expensive than the junk ones and other than the link I posted above your comment, I can't find anyone documenting the difference between the junk ones and the good ones.
    audiodave likes this.
  11. PAUL SCHULTZ
    PAUL SCHULTZ Member
    103
    66
    Michigan
    Use the About... menu in Hybrid Assistant. It has a link to their website and an entire secton on BT/OBD adapters with recommendation on one that works well.
    Paul.
  12. Cyvan
    Cyvan Junior Member
    27
    26
    Jamaica
    They've added features to remedy that.
