user interface
Discussion in 'Gen 5 Prius Technical Discussion' started by Fenichel, Jan 8, 2024.
  1. Fenichel
    Fenichel New Member
    West Vancouver, BC
    2023 Prius Prime
    XSE Premium
    This forks from issues that arose in the 12V-battery thread.
    When reasonable-size, moderate-resolution, RGB screen real estate is available, when should competent designers choose to negotiate through a small, low-resolution, monochrome screen? In particular, can anyone think of a good reason why the Prius Prime configuration options accessed through the pop-out displays on the left side of the instrument cluster are not instead found in the multimedia menus?
    Am I missing something, or was this likely to have been a project-management failure, perhaps with two teams working in different facilities and forbidden to talk to each other?
