Using 185s on Gen III?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KCobby, Feb 17, 2017.
  1. KCobby
    KCobby Member
    229
    74
    NYC area
    Hi everyone,
    I just had my 05 totaled and I'm trying to determine what, if anything, I can salvage. I may have already found another, but one question is about tires - I bought brand new tires just a couple of months ago so I was wondering if I could use these on a 2012? I know there is a difference of 195 for the 2012 vs 185 for the 2005 so I understand that it's not a perfect fit and there will be speedometer differences, but if it's possible I'd like to try it.
    Thoughts? Thanks in advance for help and advice.
  2. Burna J
    1,067
    3,336
    53
    Long Beach, CA.
  3. KCobby
    KCobby Member
    229
    74
    NYC area
    That's a great calculator - thank you!
    Looks like what I am considering would work...any thoughts to the contrary? Or problems that I might incur that I'm not thinking about?
    Thanks!
  4. KCobby
    KCobby Member
    229
    74
    NYC area
    Anyone else have thoughts? I'm assuming it's probably not as easy as just swapping wheels. But if possible, I'd like to salvage these tires. Thanks.
  5. Mendel Leisk
    40,574
    If I haven't miscalculated, going from 195/65R15 to 185/65R15 reduced tire outside diameter by almost the same factor as going to 215/45R17? The latter is our OEM, I switch over to 195/65R15 snow tires every winter, a minor difference. These are "theoretical" variations:
    In your shoes, I would sell the tires you have, stick with stock size, but it should work.
  6. Rmay635703
    Rmay635703 Senior Member
    2,647
    1,670
    Somewhere in Wisconsin
    2013 Chevy Volt
    I would stick them on and rock, you won't notice much of any difference
  7. KCobby
    KCobby Member
    229
    74
    NYC area
    Thanks for the replies! Always love the info coming from this forum, and nice to get it from people much smarter than me!
    I think I really could swap the tires, although without doing it myself, I'd be looking at spending around $20 per tire for mounting and dis-mounting. Not worth it. I also came to the conclusion that I could swap wheels (and could do that myself) - here is what I found at wheel-size.com A great resource, I found.
    Tires for Toyota Prius 2005
    • Diameters: 15.0'' - 17.0''
    • Width (mm): 185 - 215
    • Tire aspect ratio (%): 45 - 65
    • Smallest tire size: 185/65R15
    • Largest tire size: 215/45ZR17
    Rims for Toyota Prius 2005
    • Bolt pattern 5x100
      • Diameter: 15.0'' - 17.0'';
      • Width (inches): 6 - 6.5;
      • Offset (mm): 45
    Tires for Toyota Prius 2012
    Rims for Toyota Prius 2012
      • Width (inches): 6 - 7;
      • Offset (mm): 45 - 50.
    That said, I have TPMS in the 2012 so I think I'm just going to give up and get new rubber. But it was fun doing research...albeit a time vampire...:cool:
    Cheers!
  8. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    the smaller tires will hold less weight, if you solo commute in this car, it may not make a difference. I would not load it with more then 500 pounds, people and cargo.
