Using a "Jump starter" external battery to jump the Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeff S., Apr 17, 2017.
  1. Jeff S.
    Jeff S. Junior Member
    17
    Michigan
    Those jumpstarter external batteries are becoming more and more popular these days. For those of you who are unfamiliar these are lithium batteries that are much smaller and more compact than the big lead-acid batteries tow places and roadside maintaince vehicles carry around. Here is an example of one on amazon:
    They are cool because generally you can just leave them in your trunk in case you are ever in a Jam and you don't have to worry about having someone else around to help you out. They are also handy because they have USB outputs to charge other devices.
    My concern is that the jumper "cables" that you attach to the battery are rather short and are no where near long enough for the negative end (black) to reach the "recommended" discharge point on the Gen 2 prius. What do you guys think is good discharge point instead? I was thinking the screw/nut that is right next to the driverside headlight but I thought I would post about it.
  2. Currahee
    Currahee Member
    103
    34
    CT
    I always use the strut mount nuts but I think the prescribed locations are meant to be further away from each other to reduce the risk of the two clips touching and causing a short circuit.
  3. Mendel Leisk
    41,871
    Would they be overwhelmed by anything but a Prius, say a regular car or truck with alternator? (n)
    300 amp "peak power" vs 1700 amps for something like JNC660. I'm not sure myself, but would guess the latter has much more reserve and can handle bigger, regular vehicles. It's heavy/bulky though.
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    When I first got mine, its first outing was on my neighbor's Jeep Cherokee, three mornings in a row! Eventually he bought his own, but mine was called in to use yet again when he didn't realise that the little jumper packs worked better when they'd been correctly recharged. I've used mine on my Prius, and a couple of Hondas and a friend's Volvo.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    1) Be sure you get one with a polarity safeguard feature, you do not want to connect plus to minus
    2) the one I own is good to 2.5 liter engines. There are more robust models
