Using a really old 140 watt inverter in 2012 V's 12-volt ?
Discussion in 'Prius v Accessories and Modifications' started by Kereneni, Nov 27, 2019.
  1. Kereneni
    Kereneni Junior Member
    I've got a 140 watt inverter (25 years old) with one three-prong outlet.
    On an upcoming road trip, I'd like to plug the inverter into the 'cig lighter' to charge my laptop while driving.
    If helpful, the inverter is a Radio Shack 12VDC to 111VAC inverter.
    Input: 12V nominal (10-15V)
    Output: 115V/140W continuous, 200W 5 minutes, 400W 0.1 second
    Any concerns?
  2. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Should be fine, I wouldn't worry at all.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    As long as the inverter isn't broken, it should work in any car's 12V outlet.
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,717
    Texas Hill Country
    First, realize that inverter is 140w which means it could attempt to draw well over 14 amps if loaded. Some designs may draw a lot of amps on startup as well. So don't even think about adding much load just because you have an AC output. Second, most low cost inverters put out a modified square wave and call it AC. True AC is a clean sine wave. Never put a motor load on a modified sine wave and some transformer loads like in power supplies may get hot. The best thing to do is to test and ensure the Prius' limited amp outlet can take it and the load does not get hot.
  5. fuzzy1
    10,170
    Don't even dream of pulling 140W for even a few moments. The inverter may be fine, but the Prius 12V 'cig lighter' outlet is likely to blow its fuse.
    These outlets were originally meant for only 10A, or 120W. While some vehicles have these upgraded to higher currents, the Prius doesn't seem to be among them.
    Anything over 100W on the inverter output is likely to require 120+W on its input, the reasonable limit for the car's 12V outlet.
  6. jerrymildred
    11,511
    14,113
    Tampa, FL
    Definitely check the laptop's power supply requirements. Mine is only 85 watts, but yours might be much higher.
    As long as the computer can work on the output of the inverter, and it won't pull too many amps, you should be OK. Just don't get carried away and plug more stuff into the inverter.
    Honestly, though, we haven't taken our inverter long in decades. Charging the laptop overnight seems to get us through the day fine since our phones are now so capable.
  7. Centerpunch
    Centerpunch Active Member
    147
    136
    OH / NC
    2017 Prius v wagon
    Another idea would be to purchase a car adapter for your laptop. They’re available for most popular models.
    That way you’re not adding the losses from converting 12vdc up to 110vac and back down to low laptop voltage (which is maybe 20vdc).
    There are ones designed for specific laptops, and also semi-universal models like this one.
  8. Kereneni
    Thanks, everyone, for your responses. Didn't intend to ghost this thread - I shot out of town the very next day.
    I'm thinking better safe than sorry, and I may just try to re-home my vintage inverter to a friend who will likely welcome it into his cache of such things. :)
  9. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Worse, some put out a sawtooth wave that will absolutely kill most electronics.
