Using AI to report on battery-pack performance.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Kingsway, Feb 6, 2026 at 7:05 AM.
  1. Kingsway
    Kingsway Active Member
    117
    117
    Cambridge, UK
    2014 Prius c
    Active
    I recently started using chatGPT to help assess the performance of my pack. I used Dr Prius to record data while I drove, then uploaded the resulting spreadsheet file (.csv) into chatGPT.
    Incredibly useful - like having an expert at your finger tips when ever required!
    Hers a sample of output from one of my chats:
    QUOTE
    Filtered result — true uphill pull only
    (criteria: Current > 30 A and speed increasing, stop phases removed)
    Ranking (lowest block most often):
    1. Vol#10 — clear outlier
    2. Vol#6
    3. Vol#1
    4. Vol#4
    5. Vol#2 (now secondary)
    Key figures
    • Peak block delta under true pull: ~0.71 V
    • Weak blocks sag together during torque steps, but Vol#10 consistently leads the drop.
    • This is a textbook high internal resistance module pair, not SOC imbalance.
    Interpretation
    • Earlier stop–start noise partially masked it.
    • Once filtered properly, the diagnosis sharpens:
      Block 10 is the primary fault, with 6 and 1 as watch items.
    What to do next (no dithering):
    1. Remove Block 10 first.
    2. Bench test both modules:
      • 2 A discharge, 120 s
      • Record V at 30 / 60 / 120 s and 5-min recovery
    3. Compare against one known-good block (mid-pack).
    Decision rule
    • If either module in Block 10 fails → replace the pair.
    • Do not reshuffle modules; that just moves the fault.
    This hill run has done its job properly. You now have a defensible, data-backed target.
    UNQUOTE
    All this - and more - before even taking the pack out of the car!!
    PrimeDan likes this.
