Using B often...Good or Bad?
Discussion in 'Gen 2 Prius Main Forum' started by Brian, Apr 27, 2004.
  1. Brian
    Brian Member
    480
    Bakersfield
    I use the B mode to slow down often. When traveling at 45mph and see a stop light, I pop it into B mode and slow to a stop. Then back to D. Is using it as often as I do, bad?
    Thanks
    Brian
  2. xlarimer
    xlarimer New Member
    135
    berkeley, california
    hmmmmm.. I use the brake and listen technique. It keeps my hands on the wheel and allows me to prepare for a speed increase when the light turns green.
    [I work for a software company that coordinates traffic lights. ;)]
  3. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Yes, you are reducing your efficiency somewhat. Using "B" uses the engine to slow the car. Just leave it in "D." Look ahead, and see what the lights are doing. Coast as often as possible in traffic. Right now, I'm beating my combined EPA figure by 9.6 mpg in my classic. EPA combined for my car is 48, and the computer is stating 57.6. While my computer is optimistic, this will still be a new high tank for this car.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    There's one technique that says use D to brake until you hit about 24mph or so, then use B for max regen.
    Using B uses engine friction which cannot be regenerated - it doesn't force maximum regeneration.
    Also remember, in the end, a set of brakes is much cheaper than rebuilding an engine way down the future. This probably isn't as much of an issue in the Prius though.
  5. Brian
    Brian Member
    480
    Bakersfield
    Ok, so I should really limit the use to just going down the hills. Thanks For the help.
    Brian
  6. Frank Hudon
    Frank Hudon Senior Member
    4,147
    use it 4 day's a week, I have a hill on the way to work that is 13% grade for 3/4's of a mile and there is a traffic light at the bottom. Pop it into B and it will hold me at speed (no increase) and it keeps the SUV's a cars off my bumper, then use D and brakes to slow to a stop. I'm one who goes with the flow, and the gas for the Prius is a lot less than the Tundra.
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    This is really splitting hairs, but split them I will....
    It's actually at 20mph (exactly) that efficiency is improved by using B rather than braking. At 21mph and above when you use B the ICE will kick in, even if you were in stealth before using B. But, below 21mph, if you're in stealth, the ICE will NOT kick in but you'll get maximal regen.
    I've tried this, 20mph is VERY slow and the minimal improvement in regen vs. the risk of being rear ended and difficult timing of dropping into B then braking below 8mph (when regen stops) and going back into D is just too much for me to fuss with.
  8. HTMLSpinnr
    5,341
    920
    251
    Evan, I was guessing on the number - I knew it was somewhere around there when the ICE kicked in on B mode. Thx for clarifying.
  9. Brian
    Brian Member
    480
    Bakersfield
    I started doing that trick, waiting till about 20mph and then pop into B. And at the stop back into D. Now, using it OFTEN as in every 5 min from D to B and back to B, every 5, bad for the car? don't want to brake it when i am just comming up on the 600 mile break-in finish point.
    Thanks
    Brian
  10. KMO
    KMO Senior Member
    1,562
    439
    Finland
    2023 Prius Prime
    Did it ever occur to anyone that if Toyota thought it was a good idea to use engine braking to decelerate from 20 to 6 they would have programmed the computers to do it already?
  11. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I've tried this, 20mph is VERY slow and the minimal improvement in regen vs. the risk of being rear ended...[/quote]
    I agree with this concern, many people aren't paying enough attention on the road. The brake lights serve to inform those behind that you are slowing down and 'B' will slow the car more than average. Someone behind might not notice the 'increased' decrease in speed. Of course, I guess one could be on the brake pedal just enough to activate the lights for safety.
  12. efusco
    19,891
    1,192
    Nixa, MO
    KMO,
    I don't think there's any practical way they could have programmed it that way, how would they know you always wanted to slow at that pace? What makes you think Toyota thinks it's a bad idea to use B mode b/w 20 & 8?
    Look, I already made it clear that I don't think this is a practical or even a very safe practice, but I just sorta get tired of the old "if it is a good idea Toyota would have done it this way" arguement, it just doesn't hold water. In this case, however, it does seem very impractical to use B-mode (preprogrammed or otherwise) at that low speed and in that narrow band.
    --evan
  13. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    The "If Toyota had Wanted You To...." arguement is fallacious most times for one reason.
    In an automated system, the designers go for a middle ground.
    Take an Automatic Transmission for example. It shifts at a certain Load/RPM because that's optimal for a combination of factors: Mileage, Acceleration, Noise.....
    That DOES NOT imply that the chosen shift point is optimal for all situations.
    That's why someone with a Stick can Downshift and up the Revs when they want, or Upshift sooner to save fuel when they want.
    The Human Mind is an amazing thing. It can take all kinds of complex variables, and process them in combinations that computers still can't. Not to mention the fact that the computer can't read your mind, or know what is ahead on the road, or what is behind you.
    Toyota clearly couldn't make "B" mode the default because of lots of reasons. It is less mileage efficient, and if you took your foot off the gas in traffic, instead of a slow coast/down you'd slow like a you had an anchor out. That's clearly not appropriate for ALL situations.
    But, that in no way implies that there's any problem with doing something different when you know the road ahead, and there is no one behind you, and you know what you're doing and why.
    We know that B below 20mph DOES regenerate more vigorously, and this gives us a choice.
    Choice is good, as long as it's applied with the proper brain power behind it to avoid making stupid choices.
    Just as someone with a Manual Tranny wouldn't downshift with a Semi 2 feet off their rear bumper, we have to assume that an operator wanting to use B mode has just as much common sense as someone driving a Stick Shift :p
    And, to flip the arguement around:
    If Toyota hadn't wanted you to use B mode, they wouldn't have put it there!!!!!
  14. KMO
    KMO Senior Member
    1,562
    439
    Finland
    2023 Prius Prime
    I find it hard to reconcile these two statements. Does slowing below 20 using B regenerate more power? If so, surely it's more mileage efficient.
    I must confess I don't quite understand what people are trying to achieve by using the B button.
    No, that's not what I mean. I mean they could have programmed it so that if you lightly pressed the brake pedal below 20, it acted like B mode.
  15. rockluvr
    rockluvr New Member
    155
    Denver, Colorado
    It is designed to be used when going downhill to slow the car down instead of using your brakes. This is especially important when traveling in the mountains where on steep downhill slopes, brakes can burn out. I personally don't see that you need to use it during other times. On "normal" hills like those here in the Denver area, B mode is unnecessary and I don't use it.
  16. Tempus
    1,690
    Washington DC
    Above 20 MPH, B Mode is indeed "Engine Braking". It bleeds off power by spinning the ICE, presumably with varying degrees of Fuel-Less compression.
    Below 20 MPH, the B mode is NOT "Engine Braking". It does not spin the ICE, but instead relies on increased resistance from the MG(s), which in turn produces greater electricity regeneration.
    Thats why you see the Japanese 'Power Mileage Drivers' who have this particular peculiarity down to a science using it when slowing below 20 MPH.
    And no, it's not contradictory to say that having B mode engaged all the time is more fuel-inefficient, because there are times you want to lift off the accelerator and NOT slow down.
    Lightly pressing the brake below 20MPH results in much less braking that B mode. It's a significant amount of slowing, and cannot be modulated, so that's not an option.
    If B were engaged all the time, you would only have two options, accelerate or brake, unless you were the perfect 'featherer' finding the dead zone when you wanted to not accelerate or maintain speed.
  17. KMO
    KMO Senior Member
    1,562
    439
    Finland
    2023 Prius Prime
    Aha. So how's that different from pressing the brake pedal slightly harder? Don't the first few stages of braking rely purely on adjusting the MG load? The Toyota blurb suggests that the hydraulic brakes aren't activated at all until fairly heavy deceleration is required.
  18. Tempus
    1,690
    Washington DC
    Without exact data, who knows exactly how much regeneration can be obtained by the brake pedal before the mechanical brakes engage, or if B mode provides more regeneration than the system would allow through brake pedal manipulation before putting pad to metal.
    Maybe one of the Japanese researchers has some hard data.
    But, in any case, low speed B mode ensures that you are not engaging the mechanical brakes, and that all your decelration is producing electricity.
    If you were doing it yourself via the brake pedal, you would not know when you have started using the mechanical brakes and thus lost some amount of regenration.
    So if you slow using B mode, you can safely say that you have maximized regeneration, which is not something you can be sure of using the Brake Pedal.
  19. norman
    norman New Member
    77
    Australia
    I was reading a post somewhere that one person keeps bumping it into "B" whilst on the freeway (by accident) and the car immediately decelerates with no brakelights posing a traffic risk. He says it's happened 3 times by accident.
    Does anyone have any thoughts on how to avoid accidental selection of "B" at high speed. My car hasn't arrived yet, so I am also curious about how to "dissengage" B rapidly if it was selected by accident.
  20. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    Hmmm... I'm hard pressed to figure out why anyone would ever intentionally leave "D" in freeway traffic, and thus accidently bump it into "B". No reason with a Prius to put the car in neutral in stop-and-go traffic.
    Unless somebody kept bumping the shift knob? I haven't been in a Prius enough to know if that's likely.
