Using Engine "B"rake as Slowing Method
Discussion in 'Newbie Forum' started by LEILANI, Feb 28, 2008.
  1. LEILANI
    LEILANI Going Green with Barcelona Red
    Alexandria, Minnesota
    :confused:Just drove home our '08 Prius Pkg. 4 last weekend. Salesman told us the 'B' in shift lever is for the rare occassion that battery needs to be 'charged up' (he had asked service man who told him a person may only need to use it twice in the life of the car; same thing as down shifting). When he mentioned 'down shifting' I figured I would use this method when wanting to slow from, say, 40 mph to 30 mph rather than brake. Is this hard on the engine or even what the 'B' on shift lever is for??? Definitely a newbie!
  2. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    It's not hard on the engine, but its purpose is not to charge the battery. It means "engine braking", and should be reserved for use only on extended downgrades (like a mountainside) where you wouldn't normally want to ride your brakes. For the sake of your "newbie-ness," I won't take time to explain why, but to use it in everyday driving will cost you fuel mileage and is totally unnecessary.
    If you want more background on its use, you can search the PC forums. Lots of threads available.
    Welcome to PriusChat!
  3. richard schumacher
    7,663
    1,038
    United States
    As a former Saint Paulite, offhand I can't think of any place in Minnesota where you would need to use B. Leave it in D and use the brakes. Salesanimals will say anything rather than admit that they don't know something.
    Some people find that B gives them better control of the car on slippery surfaces at low speed, but try it without first.
  4. LEILANI
    Thanks, Richard and Jim! I will save the 'B' for the Rockies when I return to visit my roots. You guys helped without making me feel idiotic. Any other pointers I should keep in mind before wasting trial and error? I will check out threads on engine braking, as well. :)
  5. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Here's a lengthy explanation of B-Mode.
    :hail:Hobbit has lengthy explanations of lots of things, actually. :D
  6. Mag Gris
    Mag Gris New Member
    Media, PA
    Thanks to PriusChat . . .
    ... I'm not using the "B" mode anymore either! :clap2:
    Been driving our Mag Gris for only 3 days, but I've using the "B" as though it were a downshift/lower gear in a manual car. I thought it was great - - except that I kept forgetting to take it out of "B" when I started accelerating again (duh!) :eek:
    Our salesman made it sound like a good thing to use - and I didn't question him about it then - too many new things! - later I consulted the manual, but didn't find much, then thought to check here, luckily before ruining my gas mileage and maybe the engine brake system!
    I LOVE these forums! :wub:
  7. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    OMG, other dealers crack me up!!!:frusty:
  8. richard schumacher
    7,663
    1,038
    United States
    The Rockies, definitely :_> Nobody is born knowing this stuff so we should always be gentle, at least the first time.
    Other pointers? If the last pip on the gas gauge ever starts flashing, buy gas immediately. Don't overfill. Consider using 42/40 PSI in the tires front/rear for better fuel economy (but a harder ride). Follow the scheduled maintenance guide and do only what it says; don't waste money on a dealer's prix fixe menu of services.
  9. LEILANI
    :first:Mag gris, Have you been listening to the rest of these comments? I am also very happy to have found this site! It is going to help me much more than I ever thought would be possible. Terrific! Let's keep reading!
  10. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Welcome to PriusChat, LEILANI. Remember that your Prius is mostly computer controlled, with you telling the computer what you want.
    The computer runs the Internal Combustion Engine for lowest emissions, which means good fuel economy, and it's hard for you to actually control it. When you select a "gear" like D or R, you're flipping a switch to tell the computer the direction you want to go, and it's smart enough to know that P or R is a bad idea when you're whizzing down the freeway, so it will ignore a selection like that. When you step on the GO pedal, you're telling the computer you want to go in the direction you selected and how urgently, but the computer balances the use of the electric motor and the ICE to give you what you want while trying to minimize emissions. When you press on the STOP pedal, you tell the computer you want to reduce your speed and how urgently, but the computer decides how much energy to pull out of the generator, and how fast, to slow you down or to use the friction brakes.
    Other computers track how fast wheels are spinning and keep them at the same speed. A computer senses if the car is not going in the direction of the front wheels and corrects it. And there's a computer for the display and radio. There's a computer to make sure the high voltage battery is optimally charged. And the computers all talk with each other over three different networks. A Prius is a rolling data center!
    And the best part is, you don't have to worry about any of it. Just step on the pedal and go! Happy driving! :car:
  11. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Welcome Leilani. I have not used my B at all...I have 5K miles right now. I was told that the B may be used to slow down the vehicle without using the brake. That is all I know about it...but one thing you should not do is to accidentally shift from D to B while travelling above 50 or 60 mpg...This will probably be a little hard on the engine. I would agree that using the B often will decrease your mpg results.
    :cool:
  12. Bill Merchant
    4,096
    81
    Hey, N3FOL, "shifting" to B at any time won't stress the engine. You're just telling the computer to waste energy. The computers take care of the Prius.
  13. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Ok, here's a little secret: I use every once and a while during my daily commute in the relatively flat-as-a-pancake Chicagoland area. But don't tell anyone, ok?
    Why? Because every once and a while, there's some hurry-driven motor-head riding my butt in stop-n-go traffic. It's not like I'm going to drive through the fifteen cars in front of me so just stay off my bumper! When mental telepathy fails (the Jedi mind trick only works on intelligent beings), I shift into . This way, I reduce speed very quickly without tail lights. This causes the guy behind me to freak out and have to slam on his brakes a couple times before he finally stays back in case I suddenly slow down without warning again. Once he's caught on, I shift back into [D].
    I realize that this reduces my mileage for that little bit but it reduces my aggravation and is sometimes a little fun.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Tony, I did something like this one time in a Ford van. It was with the brakes, so brake lights were showing, but the results were somewhat different than expected. We were driving down the highway at 70 when some jerk came up from behind and started riding our rear end. I couldn't imagine why he didn't just go around us; the road was clear with two open lanes. I decided to slow down and make him go around. When I tapped the brakes he banged into the back of us, then swerved back and forth across all three lanes. After that he fell way back for a while, during which time I called him in to the police. A bit later he flew by, mostly on the grass off the right side of the road, narrowly missing signs and bridge abutments. After about 20 minutes, three police cruisers moved and and did a rolling road block and pulled him over. He had a blood alcohol content that would power most flex fuel vehicles. Fortunately no damage was done and no one was hurt.
    Tom
  15. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I went to Alex Tech College... graduated in 99 :)
    I lived in your area for a total of 14 years... 12 out South of Kensington.
    okay, thanks for the memories... :focus:
  16. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Oh, you DO like to live dangerously, don't you? :eek:
    One day, you'll do that, and the idiot on the cellphone behind you won't catch on, until they ruin the back bumper of Priapus!!
