Using Factory Wiring for Fog Lights?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Azfalconfixer, Sep 29, 2012.
  1. Azfalconfixer
    Azfalconfixer Junior Member
    46
    Peoria, AZ
    I'm going to add fog lights to my 2012 3, I have the grill on order. Seen lots of threads on running all new wiring for them but can't find anything on using the factory wiring. The wiring is there, the plugs are tied up by were they mount. The fuse is in the fuse box. I guess I could change the stalk but it seems like there should be a way to find the trigger wire and just run switched power to it. Then maybe the indicator light on the dash would also work. Has anybody done this or installed the V light stalk?
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    There is no wiring for the fogs. That's why u see us using a relay harness. I wish it was that easy but it just isn't.
  3. Azfalconfixer
    46
    Peoria, AZ
    Yep you're right I was thinking my wifes Prius C3. It does have the wiring.
  4. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    50
    Tampa, FL
    I did notice a spare plug when I took my bumper off.
    iPad ? HD
