Using Oil
Discussion in 'Prius v Technical Discussion' started by fikey13, Apr 10, 2012.
  1. fikey13
    fikey13 Junior Member
    virginia
    Up until my last oil change at 105,000 miles, I didn't notice any oil usage. When draining my oil, it didn't look like it was quite 4 quarts. After the oil change, I ensured that I had the engine EXACTLY topped off to the upper mark on the dipstick. Around 600 miles later, I parked in the same location and have noticed that the oil level has dropped enough to notice. I am guessing that I will lose well over a quart between oil changes. Before I resign to the normal mechanical reasons (rings, cylinder wear, etc.), is there some other possible explanations? The loss doesn't seem to be gradual which has me looking for other explanations. I also had a Toyota mechanic go over the car and replace the other fluids and filters at 100,000 miles (coincidence I think ). Any ideas?
  2. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    You might want to re-post on the Gen-II tech forum. You might get a better response there.
