Using Park assistance to back into garage
Discussion in 'Gen 4 Prius Main Forum' started by pattom, Mar 20, 2017.
  1. pattom
    pattom Junior Member
    32
    16
    Grand Blanc, Michigan
    Has anyone used Park Assistance to back into your garage? If so what do you do?
  2. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Since it requires starting near but perpendicular to the bay, it's usually a non-starter. Perhaps it's easier for some driveway configurations? Either way, it needs two reference points, so you're looking for a single-width garage door or a double with another car already parked.
    Not generally recommended; I haven't tried.
    RCO likes this.
  3. pattom
    32
    16
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    FYI, It only needs one reference point and it will park close to whatever is on that side.
    RCO likes this.
  5. wrprice
    415
    308
    Houston, TX
    Four Touring
    I learned something new, thanks.
    RCO likes this.
  6. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Don't use it for your garage! It's mean't for parking spaces in the open. I wouldn't trust it to clear the opening and the sidewalls in mine.
  7. RRxing
    RRxing Senior Member
    2,541
    1,816
    NEPA
    Backing into a (typical) garage can lead to CO buildup if the car is left to idle too long. It should be okay if you're just going to start it and pull out.
  8. 'LectroFuel
    880
    673
    Yeah, my exhaust pipe would be right next to my gas central heating and water heater. Yikes! Ka-boom!
  9. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    This is correct for conventional ICE engine car. In a hybrid like Prius the reverse gear is pure electrical.
    kithmo and RCO like this.
  10. wrprice
    415
    308
    Houston, TX
    Four Touring
    I think the point is that when backing in the exhaust may exist within the garage air in higher concentrations and is often closer to the entrance to the house interior. That's compared to head-in parking which puts the tail pipe near the exterior perimeter, facing out the big wide hole you drove through.
    Granted, the Prius not only uses electricity for reverse but does it's best to shut off the ICE during reverse (since it adds torque in the wrong direction in that case). Still, even in a Prius, the engine can idle and WILL run even in reverse, depending on the HV SOC%.
    RRxing likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    As long as the garage door is open and you don't leave it running unnecessarily, it should be OK!(y)
    RRxing likes this.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    ICE will also run when the engine is cold, so it could start up when driving out of the garage next day if reversed in.
    RCO likes this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Again, very true, but if you don't loiter and the door is open you won't have a problem.
    kithmo likes this.
