Using PIP As A Generator
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by El Dobro, Oct 29, 2012.
  1. El Dobro
    El Dobro A Member
    6,978
    3,213
    Tracksyde likes this.
    49,371
    i hope the liars don't prevent us from getting this someday.:cool:
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    I could use one....
  4. lensovet
    2,614
    496
    Burlington, NJ
    This would be the cleanest, most fuel-efficient generator on the planet!
    First, though, you'd need to figure out how to get the engine to charge the battery, even without drawing juice.
  5. Germwise
    Germwise Junior Member
    47
    What about leaving the car on with the radio/ac off?
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    AT $94,500.00 Yen, that's $1182.19 usd
  7. lensovet
    2,614
    496
    Burlington, NJ
    That'll keep recharging the 12V battery but no way will that fully recharge the traction battery.
  8. El Dobro
    El Dobro A Member
    6,978
    3,213
    Prius owners in Japan were using Prii as generators after the eartquake and tsunami there. That's where Toyota got the idea. The cars usually ran two days on a tank of gas.
    Scarface2005 likes this.
  9. bisco
    49,371
    there have been quite a few threads here over the years, but no one has been able to pull off a turnkey system that operates directly from the traction battery.
  10. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    ...I just think this is tremendous benefit of HEV if it doubles as emergency generator.
    Sort of like iPhone is more than a phone.
  11. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    My apologies for being so dense, but does this mean we can buy then? Couldn't tell if they plan to release it here, or if it is compatible with 120V AC systems (article indicates 100V, but not sure if it is adjustable etc).
  12. lensovet
    2,614
    496
    Burlington, NJ
    It appears that the PHV plug is slated to become available in Japan on November 1.
    Btw, I just realized: you can buy a 12v to 120V converter and just use that! I actually have one of these things. Your main issue is amperage limitations, but I believe the one I have goes up to 15A. If the car is turned on, it will prevent the aux battery from getting discharged by this.
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah, the one you mention is 180 watts, The PHV Plug is rated at 1500 watts
  14. Electric Charge
    545
    133
    Syracuse, NY
    Plus the 12V outlet is limited (thought I read ~10A).
    This has a lot of potential, not just for 'home' use, but having a portable generator (tailgating, stargazing, etc.), especially if it can run from battery for a while.
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah, 3000 watts ......so maybe 2 hours at 1500 watts?
  16. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    I really hope they release a home generator system someday. At some point I want to build an off grid house using hydro power. In addition to the hydro system and batteries, if I could use the pip as a backup generator and extra storage system that would be awesome.
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    wouldn't a portable gas generator be just as efficient?
  18. Jimbo69ny
    712
    107
    Ithaca, NY
    But then I would have to buy one. If I already own a car that does it then I wouldnt need a generator. Plus a generator wont have batteries built in (unless you buy that option) and its not portable like the pip would be.
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    the adapter cost's $1189.00 what the cost of a portable generator? the battery capacity is 3kw, right? so.......1500 watts=2 hours run time
  20. Jimbo69ny
    712
    107
    Ithaca, NY
    Do you want a list of reasons why I want the pip to do this PK?
    Here are a couple more;
    The pip is much quieter than a generator.
    The pip has emissions systems and will be better for the environment.
    Generators can cost as little as $200 and go to more than $10,000. For the power Id want I think a pip would do nicely.
    DadofHedgehog likes this.
