Using power strip for charging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by TrinaF., Jan 12, 2017.
  1. TrinaF.
    TrinaF. Junior Member
    74
    23
    Southern California
    Is it okay to use a power strip to plug the Prius in? Using the power strip as an extension cord, making it easier to plug in the car. However, the last two times it's shut itself off. I'm suspecting the car is taking too much power from it?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    The car draws about 12 amps, so a power strip is not a good idea.
  3. TrinaF.
    74
    23
    Southern California
    Thanks!
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The car draws a LOT of power.
    There are threads here about folks houses catching fire due to old electrical circuits.
    I would have an electrician wire a receptacle where it was convenient to charge.
    15 amp, 110 volt is fine for the included cord.
    30 amp 220 volts if you want level two charging, but that is about $500 more expensive.
    Pluggo likes this.
  5. mrbigh
    3,686
    699
    Long Island, NY
    Again, a power strip is NOT a good idea at all.
    Please, use a well rated (15 Amps) extension cable, not exceeding 25 feet for this particular task.
    priuscatprimeguy likes this.
  6. bisco
    49,371
    get a good 6 or 12 foot 12 gauge extension cord. it's worth it for your safety.
  7. trescenzi
    trescenzi Junior Member
    29
    42
    CT
    Ive linked a thread below where some people have posted cords they have had success with. The ones I've used are linked in there along with a few others. But basically what bisco said. 12 gauge and the shorter the better. They aren't cheap but we're talking about your car and your safety here it's worth the investment in a quality cord.
    I hope this link works. I'm on my phone so not sure it will.
    extension cord specs | PriusChat
    iPhone ?
  8. horent135
    horent135 Junior Member
    44
    CA
    2014 Prius Plug-in
    I think manual does say Do Not use power strip. They recommend using extension cords.
  9. bisco
    49,371
    toyota does not condone extension cords, but you gotta take personal responsibility at some point.
