Using techstream generate Error code : c1659, c1203, c1345, B2060 on Prius 2010 145k miles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hcarddss, Mar 9, 2020.
  1. hcarddss
    hcarddss Junior Member
    Hello,
    I use techstream and get error code c1659, c1203, c1345, B2060. The dash board has the light on of pvs, abs, and couple other light. I don't know if the actuator bad or ecu. Any ideas, Thank in advance
  2. ChapmanF
    18,523
    Or even if it's either of those at all and not something else. Have you looked those up in the repair manual (more info) yet? What are their detection conditions?
    I remember C1345 and that's an easy fix; just means the brake actuator wants to re-learn a calibration value, takes a matter of seconds to do.
    The others are not codes I have on the top of my head; I would recommend just looking them up, and following the troubleshooting steps given there.
  3. hcarddss
    Thank you, ChapmanF
    Just got repair manual, will look it up this weekend.
  4. PNP3
    PNP3 Junior Member
    28
    Philly
    Any luck with fixing these codes. I'm having same codes
  5. ChapmanF
    18,523
    Well, so far in pretty much every thread where somebody had a C1345 and followed the steps in the manual to relearn the offset, that one got 'fixed'.
    This particular thread has some other codes in it that I don't have off the top of my head, but the idea of looking them up in the repair manual to see what it says about them never grows old.
