Using the backup camera on interstate?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ewingman, Feb 18, 2008.
  1. ewingman
    ewingman New Member
    I have a 2008 Prius pk #2. It would be nice to be able to use the camera to see behind you when traveling on the interstate. Is there any way to make this mod or add another camera without messing with the warrantee? Thanks.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Yes, you can do it, but it involves stopping and shifting into reverse. This is generally a bad idea on the interstate.
    Seriously, there have been a few posts about this modification. It can be done, but it takes a bit of work. A google search of PriusChat should find the old threads.
    Tom
  3. SpartanScott
    SpartanScott Michigan Member
    60
    Howell, Michigan
    I followed instructions on an old thread. It will total you $4-6 in parts and 1-2 hours of your time. I installed the switch to look very OEM. In the attached pic the "Camera-ON" switch is in the middle, with EV button on the left. I've gotten many WOW!s and puzzled faces from passengers when turning the camera on while driving.
    On a side note if you are at all interested in adding an EV button I suggest doing so at the same time while the dash is apart. Another $4 and a hour of your time and you will have two new mods to show off.
  4. joerdie
    joerdie New Member
    61
    Cincinnati Ohio
    EV Button? Whats that?
    never mind... looked it up and found out. (Using just the battery.
  5. Gilbert
    Gilbert Member
    255
    mind sharing how to do the modifications? and what exactly do we need for them? thanks.
  6. Kaibz
    Kaibz New Member
    Maryland
    Here is a link to very detailed step by step "how to" with great pictures. Unfortunately, I don't have the center speaker so can't do it the easy way (you will see what I mean after checking out the instructions).
    EV page
  7. darelldd
    6,059
    389
    Northern CA
    Hey. Beat me to my own page! :) Yikes! There are some serious formatting issue on that page. Let me get 'er fixed.
    Word of caution - this mod is USELESS to see behind you on the road. It is a fish-eye lens. Unless what you want to see is about 3' behind you, this isn't gonna help. Trust me on this. It is a fun toy, and my daughter loves watching the dashed lines go by, but you aren't gonna use it for real rear visibility while moving at any speed.
