Using the Primes 120v Charger at 240 Volts, Cost $20 !!!
Discussion in 'Prime Plug-in Charging' started by Rob43, Mar 16, 2019.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,045
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Here's a picture of my last recorded temperature reading from dead to a full charge. I had about a ~14 degree difference, my ~74 degree temp gun reading was taken at about 2:15 (95% of charge) minutes into the charge cycle.
    Rob43
    Arctic_White likes this.
  2. Rob43
    Rob43 Senior Member
    1,373
    1,045
    2013 Prius v wagon
    Forum member "Joetech" made a helpful video about 120v to 240v Dryer Plug charging.
    Good job Joetech !
    WOW! Toyota Prius Prime 120v Charger charges at 240v?
    www.youtube.com/watch?v=E3it0SvRYoM
    Rob43
  3. Rob43
    Rob43 Senior Member
    1,373
    1,045
    2013 Prius v wagon
    Arctic_White, DavidA and bruceha_2000 like this.
  4. Q Ng
    Q Ng Junior Member
    Chino
    2018 Prius Prime
    Thanks Rob43 for the detailed information, research you have done and the links. I have ordered all the parts and look forward to using the extension on my dryers 240v outlet. My gas dryer uses the 120v to start, so the 240v will be free.
    Rob43 likes this.
  5. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    It says maximum 15A, but charging at L2 is 16A so this is a safety issue.
  6. Rob43
    Rob43 Senior Member
    1,373
    1,045
    2013 Prius v wagon
    Nope, that's where you are wrong...
    When someone uses the Toyota OE 120v EVSE at/for 240 volts, the amp draw is ~12 Amps. (It's really a tiny bit less than 12 amps)
    Also per the manufacturer of that $13 dollar adapter, they say it works up to 3750 watts, when anyone uses that adapter on their Prime they are pulling roughly ~2623 watts. This means that the adapter is only working at about ~70% of its rated capacity.
    Rob43
    #66 Rob43, May 8, 2019
    Arctic_White, bruceha_2000 and utsug like this.
  7. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Great find Rob. That is the sort of thing that I figured must exist somewhere since all you are doing is connecting wires from one 3 'contacts' plug format to another.
    Seems like I can squeak into a program from my power company and get a free L2 charger. I can't get the rebate on the car because I bought it 17 days before the program started (like I had a choice and the program wasn't preannounced anyway).
  8. Tha_Ape
    Tha_Ape Active Member
    271
    161
    Washington, DC
    I ended up buying a 16A/240V cable with 6-20 NEMA from BougeRV the other day ($190). The biggest push for me was having a dedicated cable at home so I could leave the 120V in the trunk (I often go places that leave me access to a 120V for hours at a time). The charger also came with the reverse of Robs find... a 6-20 to 5-15 adapter. For better or worse, I use 120V if I'm charging overnight and 240V if its during the day.
    That said, the cord gauge between the 240V charger and the stock Toyota one look identical. I wouldn't be surprised if the internals were identical too. I may get the $13 adapter just for giggles... waiting to make sure no one's charger has blown up yet though.
    #68 Tha_Ape, May 12, 2019
  9. Rob43
    Rob43 Senior Member
    1,373
    1,045
    2013 Prius v wagon
    That's great, I also like the idea of having two different and dedicated EVSE units for my charging needs.
    I have my Toyota OE (240v Level 2 performing) EVSE at home for my everyday ~2:25 charging, and I just purchased a used perfect working Non-Toyota brand 120v EVSE for $79 dollars on Ebay. I will carry my 120v used EVSE in my Prime so I always have the ability to charge if I need to.
    Rob43
    Tha_Ape likes this.
  10. randomwalk101
    randomwalk101 DYI'er
    532
    268
    texas
    I have a Nema 14-50r 240v outlet in my garage. Is there a similar adapter exist for this type of plug? Thanks
  11. Rob43
    Rob43 Senior Member
    1,373
    1,045
    2013 Prius v wagon
    After a quick search, everything I found from $30 to $60 dollars did Not give a 240v output, so they would be useless.
    Both of these examples are 120v output:
    www.amazon.com/Parkworld-886245-Adapter-14-50P-Lighted/dp/B078XBC37F/ref=sr_1_3?crid=1BJ52CXV0MF7P&keywords=14-50p+to+5-15r+adapter&qid=1557866966&s=gateway&sprefix=14-50p+to+5-15%2Caps%2C587&sr=8-3
    www.amazon.com/AC-WORKS-AD1450520-Generator-Household/dp/B077MTF8QF/ref=sr_1_16?crid=1BJ52CXV0MF7P&keywords=14-50p+to+5-15r+adapter&qid=1557866966&s=gateway&sprefix=14-50p+to+5-15%2Caps%2C587&sr=8-16
    If you'd like me to build one for you, send me a PM.
    Rob43
  12. Rob43
    Rob43 Senior Member
    1,373
    1,045
    2013 Prius v wagon
    You're very welcome.
    How is your progress on this, have you built your 240v conversion plug yet ?
    Rob43
  13. Q Ng
    Q Ng Junior Member
    Chino
    2018 Prius Prime
    Hey Rob, everything is working flawlessly with the Toyota evse. Charging time is cut by more than half. It used to be about 5 to 5.5 hr on 120v, now it is about 2 hours. Thanks again
    Arctic_White and Rob43 like this.
  14. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
    Which way is better to the battery, 120v or 240v? So the battery can last longer.
  15. Rob43
    Rob43 Senior Member
    1,373
    1,045
    2013 Prius v wagon
    Maybe you should start your own thread with this question, because it is not thread specific.
    That way you can debate your question back & forth...
    Rob43
  16. Rob43
    Rob43 Senior Member
    1,373
    1,045
    2013 Prius v wagon
    That's great to hear, congrats on your success !!
    Pictures, Pictures, & More Pictures!
    Rob43
  17. randomwalk101
    532
    268
    texas
    I want to thank Rob43 for the valuable tip of charging at 240v with stock charger and also want to thank him for making an 240v adapter for me. I got the adapter today and gave it a test. Wow the Prime now fully charged around 2 hrs from empty. Super happy and save a bunch of $$ from buying the 240v charger.
    Now some pics :) still need to put in a bracket to holder the charger properly :)
  18. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    You might consider flipping that receptacle 180 degrees so the cord can go straight down without the loop on top.
    Rob43 likes this.
  19. randomwalk101
    532
    268
    texas
    Why?
  20. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    for strain relief
