Using voice commands with phone
Discussion in 'Gen 3 Prius Audio and Electronics' started by R. Barre, Apr 20, 2015.
  1. R. Barre
    R. Barre New Member
    Los Angeles
    2015 Prius Plug-in
    I've paired my iPhone and programmed my home phone into the Speed Dial.
    I'm at a red light, I hit the speed dial for my home number, I hear the home phone ring and the answering machine pick up. I'm about to use the 0-9 virtual keypad to enter the answering machine's code, so it'll play back my messages, when the light turns green and I start to drive. Now the 0-9 keypad is grayed out, and a message says something like "Use voice-activation while driving."
    I tried saying the numbers of my answering machine's code out loud, but nothing happened. Is there a way I can use voice controls in lieu of tapping out the numbers on the 0-9 keypad?
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    I don't think you can use voice controls in lieu of entering numbers on the 0-9 keypad. You'll have to bypass the speedlock if you want to use touch pad to enter PIN number.
