Vacuum hose: help with part number?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by djimbuser, Jan 19, 2025.
  1. djimbuser
    djimbuser Member
    102
    36
    Henderson, Nevada
    I have a 2010 and this hose had a 1/8" long split at the top where it connects to the metal pipe to the right of the valve cover. Upon trying to reinstall, it split all the way down.. Pictured is an unsplit hose on my wife's 2012 however upon trying to re-install, it started to split as well!
    I'd like to replace it with a fresh hose. The other end of the hose appears to connect to the purge vsv solenoid.
    #1 djimbuser, Jan 19, 2025
  2. Tombukt2
    Tombukt2 Senior Member
    12,987
    2,328
    Durham NC
    Hayes hose mfgrs calls this emission hose . It's made to stand up to the filth that's in EGR and all of that kind of nastiness coming out of a valve cover It is especially made for this and it comes in a bunch of different sizes that's usually when discussed the size is talking about the hole in the middle which is going to push over the barb fitting in your device car or whatever You could call the Toyota dealer and they could tell you what this hose would cost from them they probably won't have it but absolutely I don't have the parts break down to tell you but gates corporation should be able to provide you with more information than you might want It's pretty common hose pretty common engine It's the same as a Corolla for the most part.
  3. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    My guess is it's the fuel vapor supply hose.
    23826-37090
  4. Tombukt2
    12,987
    2,328
    Durham NC
    It splits because emission has has dried the hose out . New hose is pliable old not sooo much
    djimbuser likes this.
  5. Mendel Leisk
    41,457
    #5 Mendel Leisk, Jan 20, 2025
  6. ASRDogman
    ASRDogman Senior Member
    7,592
    3,916
    Take that photo to Toyota, and they will find the CORRECT hose for you.
  7. Mendel Leisk
    41,457
    Seemingly avaiable, if you google the part number.
  8. djimbuser
    djimbuser Member
    102
    36
    Henderson, Nevada
    You are correct it is that part number.. "Fuel Vapor Feed Hose #1" - If the best price I can find is $29 before shipping I'll probably just use generic vacuum hose like Mendel suggested.
  9. Mendel Leisk
    41,457
    Was going to say check with local dealership, but looks like nearest dealership is close to 200 miles distant.
  10. Mendel Leisk
    41,457
    The hose I suggested is fuel line, and might be a bit more cumbersome. I've used it on oil catch cans, and it can turn through a fairly tight radius, say about 2". Just googling vacuum hose, it may also be ok: that hose is for gas "fumes". Vacuum hose will be more flexible.
    Attached gives some idea of how flexible it is. It is flattening some on the tight radius between the two cans:
    #10 Mendel Leisk, Jan 21, 2025
