Vacuum Pump location?
Discussion in 'Gen 2 Prius Technical Discussion' started by Daox, Sep 13, 2011.
  1. Daox
    Daox Member
    196
    58
    US, Wisconsin
    Does anyone know where the vacuum (brake) pump is located in the engine bay?
  2. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    The brake actuator, which incorporates the high-pressure reservoir (accumulator) and pump, is buried behind the inverter. It uses positive brake fluid pressure, and there's no dependency on engine intake manifold vacuum (no vacuum when the engine isn't running!)
    There's a copy of the 2006 Prius Service Manual at http://www.selidori.com/tech/prius/DOC/Tech2006/ - see page 211 of the Brake Control section.
  3. Daox
    Daox Member
    196
    58
    US, Wisconsin
    Thanks Mike. There is a Prius at a salvage yard here and the engine is out of it. I was thinking of pulling it as a possible part for an EV.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Keep in mind that it is not a vacuum pump. It is a hydraulic pump.
    Tom
  5. Daox
    Daox Member
    196
    58
    US, Wisconsin
    Yeah, I'm seeing that now. Interesting design. I take it that the pump runs off the hybrid pack vs the 12V then?
  6. qbee42
    18,058
    3,074
    Northern Michigan
    If I recall correctly, on the Gen II it runs from the 12V system with a capacitor backup.
    Tom
  7. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    This system is not a good candidate for retrofit into an EV, IMHO.
  8. Daox
    Daox Member
    196
    58
    US, Wisconsin
    And why is that?
  9. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    It requires some kind of computer to drive it. It is not just an accumulator pump, it is about the most complicated brake pressure provider/modulator possible. There's something like 40 connections between it and the antiskid ecu. I'm not saying it can't be done, but I think you are looking at person-weeks or months of time to get something to work reliably.
    If it were me, I would go low-tech, as in the $350 12V vacuum pump + motor that would run a conventional power booster.
