Vacuum the car while charging: bad idea
Discussion in 'Prime Main Forum (2017-2022)' started by CaliforniaPrius, Aug 20, 2017.
  1. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    The car is kind of dirty at both passenger side and driver's side floor mats and it is out of juice. OK, plug it in then start to vacuum. Bam! Power's out. And the circuit breaker at the central breaker box is at ON. WTH?
    Called several electricians around. Only one picked up. He said $240 a trip b/c it is a Sunday but he also said you'd better try to reset all the circuit breakers instead of the one you "think" controls the garage area. Miracle! Everything's back to normal.
    Lesson learned: the charger reads 120V, 12 amps which means another 9 amp from the vacuum is probably too much power draw for the circuit breaker.
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Wow, talk about a "spark" of knowledge...............
    huskers likes this.
  3. Washingtonian
    Washingtonian Senior Member
    716
    617
    I am surprised that if a circuit breaker blows that the first response is to call an electrician.
    fotomoto likes this.
  4. bwilson4web
    15,524
    I wish ignorance could surprise instead of being expected.
  5. scm2000
    scm2000 Active Member
    164
    125
    it's probably not a bad idea to vacuum while charging if you plug the vacuum on a separate circuit. -- 12+9 is 21.
  6. bwilson4web
    15,524
    Wait to the next day and vacuum then.
  7. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    or get a "plug-in vacuum" that you can charge after the Prime is charged :cool::D:LOL:
    jaqueh likes this.
  8. CaliforniaPrius
    313
    201
    Alameda, California
    I flipped the breaker back and forth which I thought was the garage breaker but no avail. I also checked other breakers. Every one of them was firmly at the "ON" position. So it is possible that even the breaker is at ON position, actually the electricity could still be cut off? We used to have a breaker that refused to stay at ON so I have an electrician changed it but this time it is different. Each of them was firmly at ON position but no electricity in the garage. Weird.
  9. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    Some brands of circuit breakers do not move the handle much when they trip. Some have a window that shows a red indicator when tripped, and the viewer needs to be lined up just right to see the red.
    A breaker can become defective and not reset. Or, that one is doing what it does properly, and it needs to be opened and closed perhaps with a good steady push in each direction. A quick flip may not allow the moving parts inside the breaker to get into their set positions.
