Validating mpg readout
Discussion in 'Prime Fuel Economy & EV Range' started by HypersonicPrime, Nov 29, 2017.
  1. HypersonicPrime
    74
    59
    NC, USA
    Has anyone validated the mpg readout on the Prius Prime with a full-empty drive? For example, start with a full gas tank, place the car in HV mode (depleted battery or save EV driving for before or after this test), reset a trip meter, drive until nearly empty, fill it up again. Calculate mpg by dividing trip meter miles by gallons filled and compare to trip meter mpg. After 2 such trips, the reading I get on the car seems to be higher than I calculate manually by about 4 mpg. I suppose for this question you could include the EV miles, but I'm doing the calculation leaving it out as to not artificially increase my HV-mode mpg estimation.
  2. DavidA
    2,328
    1,812
    Chicago western burbs
    The Prius line has always had the problem of reporting higher than actual MPG on the dash. The last two generations of Prii were between 2 and 2.5 mpg higher than long term manual calculations would reveal. I don't care anymore to figure it out, as I have known the about the error for 8+ years. As long as I keep adding electrons to the battery, and not gas to my tank, I'm happy.
    HypersonicPrime likes this.
