Valve chipped
Discussion in 'Gen 3 Prius Technical Discussion' started by Raphael Muscarelle, Oct 19, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Maybe I should replace this valve. Any thoughts IMG_20191019_192844.jpeg IMG_20191019_192657.jpeg
    51,155
    i think its a good idea(y) are they expensive?
  3. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    So is that chip carbon build up or metal damage? And considering how much work you've gone thru to get that valve out in the first place, it would make sense to be a thorough as possible and so you don't have to go through this for the rest of the life of the car. So as brand new as you can make that head before you put it back on the better...
  4. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Replace it. Your peace of mind will be worth the price. Otherwise, you will keep thinking of that valve as long as you have the car.
  5. Mendel Leisk
    40,586
    Clean it up first, for a better look?
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    IF you have gone to ALL the trouble to get it apart that far........I would suggest a complete rebuild:
    Pistons, rings, valves, seats, bearings......the whole 9 yards regardless of how the individual parts LOOK.
