Valve rattle?
Discussion in 'Knowledge Base Articles Discussion' started by duncan442, Feb 6, 2009.
  1. duncan442
    duncan442 New Member
    I have recently started to notice a rattle from the engine of my 04 on acceleration, particularly from cold start. Sounds like it is the valves....
    Is this common? Should I be concerned?
    It is due for it's 60k soon and is still under extended warranty so I will probably mention it when I take it in but I would like to get some background info first if possible.
    Thanks
    Duncan
  2. patsparks
    10,664
    567
    Adelaide South Australia
    It's most likely valve lash, no big deal. You may decide to have the valve clearance adjusted or you may not. It makes little difference apart from a little noise. Valve noise is made worse by using thin oil like 0w-15 or 5w-20 because it doesn't damp the noise but it doesn't accelerate wear.
  3. duncan442
  4. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    you know, change the oil and filter. it helped to do this once, it's worth a try.
  5. florachristi
    florachristi New Member
    2003 Prius
    By using oil and keeping the filter clean it wont get that much noise...
