Valve Stem Cap Down the Oil Return?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 419 Grease Monkey, Feb 6, 2024.
  1. 419 Grease Monkey
    419 Grease Monkey New Member
    Houston, TX
    So, after reading dozens of threads here, I decided to do the headgasket on my wife's 2012 prius 3.
    All went well, until I bumped a rocker and the valve stem cap fell down the oil return after torquing the new headgasket on. !@#$ &*^% %!@# $%^&!!!!!!!
    Has anyone here dropped anything down the oil return ports in the head?
    Does it go straight to the pan?
    Will boroscope here after I mentally reset, but thought someone here might have done something similar.
    Will post results after FOSAR with magnets/etc.
    Photo doesnt seem to upload, but its the #3 cylinder exhaust, starboard oil return I think.
    Thanks.
  2. 419 Grease Monkey
    Houston, TX
    Update:
    3/8" (~10mm) boroscope head is just to large to fit down the oil return.
    1/4" (~6.5mm) head will fit down the return and past the shelf to the oil pan.
    There seems to be a shelf at ~8" from the top of the head, and the distance to the pan seems to be ~19-20".
    My stem cap is at ~19-20", so if I can't get it with a small magnet retriever, I'll just have to take the pan off.
  3. Mendel Leisk
    38,634
  4. 419 Grease Monkey
    Houston, TX
    I did get a small boroscope down to see it @ ~19".
    Most magnetic pickups were too wide to fit down the channel, so I used a coat hanger and a very small donut magnet and it came right out.
    Thanks for the response, your posts have been a huge help in learning and working on these cars.
    I can email photos of the special tool if anyone needs, but I cant upload photos here.
    the boroscope was this:
  5. 419 Grease Monkey
    Houston, TX
    Kenny94945 likes this.
  6. Mendel Leisk
    38,634
    Good you got it. And a cautionary tale( now we know they’re tiny enough to drop in there.
