Valve stem cap lost and morning cold problem
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Nov 22, 2019.
  1. nudriver
    nudriver Member
    247
    28
    los angeles
    How common is it to have your valve stem cap fall off or get lost? One of mine is missing and I am wondering if it happened at the car wash the other day. I'm hoping someone did not remove it in the parking lot at work.
    Also, other than sitting in your car for 10 minutes in the morning waiting for the defrosting feature to clear your windows after a cold night, is there a faster way to get your windows clear? I'm not talking about ice or frost, just the mist that gathers and which, especially on the side windows, takes a long time to get rid of.
    51,155
    fairly common, if they are not tight. you can pick them up cheap at an auto parts store
    feel free to wipe down the windows with a clean towel
    kc5dlo and Ed Beaty like this.
  3. nudriver
    nudriver Member
    247
    28
    los angeles
    You mean they just pop off due to bouncing around on the road? And even if I wipe off the dew (or whatever it is) won't there still be a layer of cloudiness?
    51,155
    they shouldn't pop off if they were tight. if loose, yes.
    the other thing is, who airs up your tires. they don't always get replaced
    a clean try clothe shouldn't leave a residue. check the rain x packaging to see if it works on the inside.
    once you remove it, the hvac should keep it clean
  5. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    Condensation on window, at least in your local is easy to get rid of I would think. Just keep the window open.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Do you check your tires PSI?
    Do others...ever check it?
    It's not uncommon for valve caps to become lost. But if they are screwed back on properly, it's not going to happen.
    But at a Service Appointment that might include a "complimentary" tire pressure check, whether a technician carefully puts the caps back on is questionable.
    I know, because recently I had to have a tire patched at a tire shop. When I got home, I noticed that 3 of my 4 tires had Black colored valve stem caps, but mysteriously one was now grey. The technician was so unobservant or in such a hurry they actually put someone elses cap on.
    I didn't complain because they patched the tire for free. And because valve stem caps are really, really cheap...I have spares.
    But anyway...I would say...losing a valve stem cap? It happens...especially if they aren't put back on right.
    As far as defrosting...we just had a thread with multiple and diverse answers.
    There is a considerable art of Feng Shui settings.
    My simple advice is cleaning and drying the interior of your windows. Even if they look clean. Any substance on the inside of the window will trap moisture and slow defrosting.
    I'll leave the debate about "settings" and vent angles to everyone else.
  7. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    That would be too fast. I like to take the 10 mins to check how many likes received on self fees to boost my confidence level then drive away with clear windows.
    RMB and 2012 Prius v wagon 3 like this.
  8. Mendel Leisk
    40,584
    Mental note to self: take valve caps off whenever taking car in for service. I do that now when getting replacement tires btw.
    I've never lost a valve cap that was snugged down, likely someone neglected to replace it. Or petty vandalism?
    For the morning warmup idling to clear the windshield: any chance you could get the car into a garage? We never get frosted or dewy windshield, parking in an attached garage. West coast winters aren't that harsh, so I'm not sure if that'd apply elsewhere.
    #8 Mendel Leisk, Nov 22, 2019
  9. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    That is the solution. You need the clean your insides. Wish I can quote myself in my signatures.
    bisco and Mendel Leisk like this.
  10. The Electric Me
    9,083
    5,800
    Hey, I recently had to prep for a Colonoscopy. (too much information?)
    But trust me, I know the devastating outcome of cleaning your insides.
    RMB, jerrymildred and Grit like this.
  11. AzWxGuy
    AzWxGuy Weather Guy
    1,036
    519
    Tucson, AZ
    2021 Prius
    I always remove my valve caps whenever getting a tire or rotation service. Too many times I get back someone else's caps or none at all. I tell the service personnel that I have the caps so they don't go hunting for some. I use a metal cap with captive O-ring.
    Is the mist forming on the exterior or interior of the window? If exterior, a quick squeegee would clear that up. Interior would be another problem, mainly water accumulating inside the vehicle, vaporizing, and depositing on the glass. Gen II was known for leaks around the back hatch area, and all generations can develop a plugged A/C condensate line that backs up and leaks into the interior.
  12. Mendel Leisk
    40,584
    Good idea for a "pro" brake fluid change too: remove the bleed bolt caps. Give them a heads-up, so they don't go nuts looking for them after, lol.
    Last time I had pro brake fluid change, they managed to lose 3 of them IIRC. No mismatched replacements, nada. Oh and they left one corner with non-functional brake. Not a fly-by-night place either, an accredited Honda dealership. In Port Moody...
  13. The Electric Me
    9,083
    5,800
    With my Honda Fit, I bought some metal caps, that I thought looked great.
    Now I can't remember whether it was here or some other automotive forum, but I remember a thread where a person showed pictures and warned about metal caps that had rusted onto the valve stems, resulting in the person having to destroy his valve stems just to get them off.
    After that?
    I somewhat reluctantly went back to the plastic-but non-rusting-regular valve caps.
    Maybe I was scared off needlessly?
    But sometimes it's a better life through the use of plastics.
  14. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    My son used aluminum valve stem caps that corroded onto the brass valve stem threads due to the electrolytic reaction of dissimilar metals. Since that was an aluminum-brass reaction, it occurred in the span of 1-2 years. I was using metal valve stem extenders coated with chrome and also had them corrode into the brass threads of the valve stems, but that process took 4 years. For both my son’s tires and my tires, the cap (or extension) could not be removed without rupturing the valve and causing a leak, so replacement of the valve and TPMS sensor was required. So I have made and now am using about 2 cm longer plastic caps.
  15. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    HAHA!!!... Okay, there's enough quotes now to update my signature.
    But your right, on the molecular level having clean windows inside the car will minimize fog to moisture up so inside also.
    The Electric Me likes this.
  16. The Electric Me
    9,083
    5,800
    Yes, the thread I'm remembering was very similar to this.
    I don't know if my metal...can't remember what it was...chrome or aluminum or whatever, would of ever become a problem, but the I defaulted to even if I like the look of the shiny metal?
    Hey, they are just valve stem caps.
    Black is nice too.
    And plastic is light, cheap, durable and won't corrode. So I switched back.
  17. Coach Grumpy
    Coach Grumpy New Member
    Boise, Idaho
    RainX makes non-fogging wipes for interior glass. They work well here in Idaho.
    SM-T720 ?
  18. ASRDogman
    ASRDogman Senior Member
    7,243
    3,781
    I've never had that problem. Checking tire pressure every few weeks, even just once a month should
    stop that from happening. Sticking that is, not discoloration.
    I never coated them with anything.
    It's when they are together long periods of time the reaction continues to work. But removing them, reinstalling
    them stops the process, THAT process. Another will start sooner.
    But you shouldn't have any real problem with the plastic ones. And if you didn't, they're easy to cut off.
  19. Mendel Leisk
    40,584
  20. AzWxGuy
    AzWxGuy Weather Guy
    1,036
    519
    Tucson, AZ
    2021 Prius
    You made me go back and look at the package, and after a more careful reading discovered something even more menacing. I purchased these at a local car parts chain store (O'Reilly), where I can't even find them anymore. Part # X-Tra Seal 15-4915 at Amazon. They are High Heat Dome Caps, whatever that means. I was hoping to find a metallic composition listing, instead the first bullet on the back of the package says Do not use with TPMS valves. Wonder why I didn't see that when I bought 'em? So now I'll have to figure out why these aren't recommended. No clue, other than adding an additional .32 ounce to an already heavy spot around the diameter. I have no worries about any untoward galvanic processes between cap and stem. This is a desert I live in after all.
