Valvoline MaxLife Full Synthetic ATF - Instead of Toyota WS
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 23, 2019.
  1. ski.dive
    ski.dive Active Member
    893
    230
    Hutchinson Island,FL. Mt. Snow,VT
    My neighbor has been using Valvoline MaxLife 100% Full Synthetic ATF
    - Instead of Toyota non synthetic WS on his TOYOTA for over 5 years=NO ISSUES.
    ***And YES...Toyota WS is 'non synthetic'
    At only $17.00 a gallon @ Walmart, Valvoline MaxLife 100% Synthetic ATF -is a great alternative,to the much more 'expensive' = $10 a quart Toyota WS
    Valvoline MaxLife Full Synthetic ATF is compatible with Toyota WS.
    #1 ski.dive, Apr 23, 2019
    genonervo, douglasjre and mjoo like this.
  2. Mendel Leisk
    38,652
    I see this disclaimer:
    Valvoline does not recommend MaxLife Multi-Vehicle ATF for use in most continuously variable transmissions (CVTs) and in dual clutch transmissions (DCTs) unless specifically noted
    That said, the Prius is not a traditional CVT, more akin to a manual transmission.
    And all of that said, Toyota rarely insists you must use their proprietory fluids, but is pretty emphatic with the Toyota ATF WS, cautioning that using anything else could damage the transaxle.
    It's your car, your dice to roll. It might well be fine. But when you think about it, a transaxle fluid change is something you might do once, twice, in the vehicle's lifespan. Is it worth saving $20?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Someone waved the red flag in front of the bull :p.
    Well controlled response (y).
    kerbear54, m.wynn, Skibob and 2 others like this.
  4. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    The long list of compatible fluid specs is a sign that those on the list are more likely to be non-synthetic in nature, and that the higher grade synthetic base stock used is hence suitable in these applications. The label or PI sheet notes not for use in Honda CVTs specifically, but does not have the same warning for Toyota, most likely because this is not a typical CVT, where the exact/proper viscometrics are more crucial.
    I am personally seriously considering using it, as I consider it an upgrade, unless I’m mistaken and the Toyota WS is a synthetic fluid....
  5. ski.dive
    893
    230
    Like I said= You do what you want and spend the big $$$ on Toyota WS
    ***My neighbor has been using Valvoline MaxLife Full Synthetic ATF
    - Instead of Toyota WS ,on his PRIUS for 5 years & over 60k miles =NO ISSUES.
    Next time I change my tranny fluid -I'm using Valvoline MaxLife Full Synthetic ATF
    douglasjre and Mendel Leisk like this.
  6. bisco
    49,391
    how much is the toyota fluid?
  7. ski.dive
    893
    230
    [QUOTE="bisco,]how much is the toyota fluid?[/QUOTE]
    $10.00 for Toyota WS for only a quart @ my dealer
    $17.00 a gallon @ Walmart, for Valvoline MaxLife Full Synthetic ATF
    #7 ski.dive, Apr 23, 2019
  8. Mendel Leisk
    38,652
    #8 Mendel Leisk, Apr 23, 2019
  9. bisco
    49,391
    but it's quite a drive. i'd need another tranny fluid change after the trip. that doubles the price :p
  10. ski.dive
    893
    230
    quote- Someone waved the red flag in front of the bull :p.
    Well controlled response (y). -quote
    BULL SH*T= Valvoline MaxLife 100% Full Synthetic ATF- Will work fine,instead of Toyota WS
  11. bisco
    49,391
  12. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    :LOL::LOL::LOL:
    m.wynn and bisco like this.
  13. ski.dive
    893
    230
  14. bisco
    49,391
    that's a little better
  15. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    So you need 4 quarts, or $40.
    How often do you plan on doing the fluid change?
  16. bisco
    49,391
    same as the engine (y)
  17. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    I recall reading somewhere recently that bulls are color blind - and can only perceive few colors and red is not one of those :eek:
    Raytheeagle likes this.
  18. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    It’s an inside joke with @Mendel Leisk ;).
    Anytime a post comes about where someone deviates from Toyota ATF WS, he pounces :).
    Kept it fairly in check this round(y).
    m.wynn and edthefox5 like this.
  19. ski.dive
    893
    230
    Another thing to ponder...TOYOTA WS Transmission fluid is not synthetic
    Valvoline MaxLife is 100% Full Synthetic ATF- & Will work just fine, instead of Toyota 'not synthetic' WS
  20. bisco
    49,391
    same with the coolant too, and a/c fluid
