Valvoline Premium Blue Restore for Oil Consumption Repair or Prevention
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Nov 26, 2019.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    2011 Prius w/199K.
    No issues with oil consumption - the oil level stays near full between 5k changes.
    I am trying Valvoline Premium Blue Restore 10W-30 for a 10k interval to clean the piston rings for preventative maintenance. I intentionally used a synthetic media filter which I will change after 5K.
    This oil was co-developed by Valvoline and Cummins to clean the piston rings on ISX15 engines that were experiencing oil consumption. Supposedly this oil contains a significant percentage of a high-solvency Group V ester basestock.
    The cost is the oil is crazy expensive though - $79/gal.
    Here is some background info on the product:
    https://volvo.cummins.com/file/1380.pdf
    https://patentimages.storage.googleapis.com/e6/19/8e/24bb28eefcfd7e/US20170029734A1.pdf
    I suppose this product may be worth trying if you have a low mileage engine that consumes oil and is not worn out. Obviously the economics of the product may not make sense, but oil consumption is annoying to a lot of drivers and any improvement is appreciated.
    iPhone ? Pro
    m.wynn, mjoo, RMB and 4 others like this.
  2. ASRDogman
    ASRDogman Senior Member
    6,059
    3,252
    $80!!!! Crap! Does it change itself?
    Merkey and Georgina Rudkus like this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
    Some suckers will believe anything.
  4. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I hope it works, but i'd be concerned that it was developed for diesel engines. Cummins doesn't screw around. I mean their the world leader in Diesel engine production. But iono. Curious as to the results you achieve.
    btw - looks like you've got a decently spacious shop there. How did you manage that! lol
    The Critic likes this.
  5. ASRDogman
    6,059
    3,252
    Maybe it was a misprint... $7.9
  6. StarCaller
    StarCaller Senior Member
    1,244
    697
    Cedar Crest, NM, USA
    TheBungler, dubit and The Critic like this.
  7. Rebound
    Rebound Senior Member
    3,964
    2,612
    Portland, OR
    It’s not too expensive on Amazon — about $28 a gallon or $70 for three gallons.
  8. mikey_t
    mikey_t Active Member
    370
    391
    Los Angeles
    I'll be very interested in seeing your results. So far I've been very happy with BG EPR and MOA.
    m.wynn, RMB, The Critic and 1 other person like this.
  9. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    "High Solvency" oils have been used for years to cut the crud. Problem is, once you cut the crud, you loosen up clearances "all around". Depending on specific issue, that can be real good...or real bad.
    Respects...but I'll stick to 5,000 mile OCIs and using higher viscosity oil in "worn" engines.
    m.wynn and The Critic like this.
  10. StarCaller
    1,244
    697
    the regular blue one, not the 'RESTORE' ....
    there's not too many places where you can get it, amazon is not one of them /
  11. The Critic
    3,193
    2,321
    CA
    The product was co-developed with an OEM so this is not your typical aftermarket snake oil.
    Yep, "Restore" is the key word....big difference in formulation and in price.
    Premium Blue Restore 10W30 Gallon, 877377, Valvoline
    m.wynn, Grit, RMB and 2 others like this.
  12. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    So what's the verdict on the restore oil that was put in?
  13. ChapmanF
    15,435
    Hmm. An organic chemist I am not, but some of the fancy words make me wonder how that compares to this stuff from a few years back.
  14. The Critic
    3,193
    2,321
    CA
    On my car? We may never know because there wasn’t any oil consumption.
    But on the Accord, the consumption has dropped by a decent amount.
    iPhone ? Pro
    SFO, Raytheeagle, Grit and 1 other person like this.
  15. Tande
    Tande Active Member
    502
    302
    Mich.
    Whatever happened to "Detergent Oil".........just wondering
  16. Georgina Rudkus
    3,148
    2,202
    Taylors, SC
    Any current oil used for motor vehicles are "detergent" oils.
  17. Tande
    Tande Active Member
    502
    302
    Mich.
    But in this case (Prius).......not enough "Detergent"......:(
  18. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    Amsoil signature series and redline will suit those needs.
  19. The Critic
    3,193
    2,321
    CA
    The issue is that most engine oils are designed to maintain cleanliness, not clean up stuck oil control rings.
    iPhone ? Pro
  20. Pollymath
    Pollymath Member
    102
    37
    Flagstaff, AZ
    Any follow up on this?
    I called a local "Cummins" service shop and they didn't have it. Ryder Truck Center didn't have it either as the "Fleet" end of their business has now parted ways from the Rental side.
