Valvoline restore and protect???
Discussion in 'Gen 2 Prius Main Forum' started by Brian Adcock, Feb 27, 2025.
  1. Brian Adcock
    Brian Adcock Junior Member
    32
    NC
    Good evening
    Has anyone begun using the Valvoline restore and protect motor oil?
    I decided I would try it today. The experiment has begun.
    Brian
    PriFi and xw20_driver like this.
  2. xw20_driver
    xw20_driver New Member
    PNW
    Interested and watching for updates on your experiment. The R&P motor oil is suppose to clean away the old accumulated sludge in old dirty engines. How many miles do you have on your car? Mine is approaching 196K and looks to have a decent amount of brown buildup when I peeked into the oil filler hole.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,111
    622
    Southern California
    Mine is coming up on the second VRP oil change. Our 2007 at 140k (just a week or so ago) has been using about 3/4 of qt per 5000 miles and it is still close to that. The dipstick had a little yellow/brown varnish on it before and that is now gone. Other than that, nothing to report. I don't drive very much these days. At the current rate it will take 4 years to get through the four oil changes Valvoline says it takes for this product to do its thing. I'm not betting heavily on "restore" with respect to that (not terrible yet) oil consumption, but hoping the "protect" will keep it from getting any worse.
    Brian Adcock and xw20_driver like this.
  4. Brian Adcock
    32
    NC
    Good morning....
    My 2008 just turned 257000. I am the second owner. Fortunately the previous owner was on top of there oil changes. I also did a B&G engine treatment last year. I hope the new motor oil is not snake oil. I still believe in changing my oil every 3500 miles.
    xw20_driver likes this.
  5. Brian Adcock
    32
    NC
    I totally get it. I am with you on your hopes. My 2008 was using about a quart every 4000 miles. I did a B&G engine treatment last year. I thought it is worth a try on the new Valvoline. I will use it for 2025 and change my oil every 3500 miles and evaluate things later in the year.
    We drive my Prius primarily to keep miles off of my wife's fiesta.
  6. Mendel Leisk
    40,236
    Brian Adcock likes this.
  7. pasadena_commut
    2,111
    622
    Southern California
    Yes, zero is included in the range "up to 100%". The stuff does take varnish off of metal. It isn't clear to me under what conditions it would remove the really tough stuff that locks in the oil control rings, or if the Prius with its motor off half the time, is in that cleaning state often enough for it to work on that car.
  8. losi
    losi Junior Member
    california
    I bought 5L of restore and protect from Napa for my next oil change. I noticed the restore and protect oil has a very different smell than the regular motor oils. I am suspecting the additive package is much more aggressive.
    My 2006 prius has 206,000 miles. It burns roughly 0.1-0.2L oil every 500 miles. Not good, not great. I am interested to see if any reduction in oil burning occurs.
  9. Brian Adcock
    32
    NC
    I noticed the smell and the darker hue of the oil right out of the bottle.
    I am not a gambler but I am hopeful.
    My guess is this is a weaker B-G package in a different bottle. I do believe that B&G is a very good product that did help with my oil usage.
    Keep me posted!
  10. Brian Adcock
    32
    NC
    Ahhh the fine print. Lol
    I believe given the odor and darker color out of the bottle this is a weaker B-G package in a different bottle. I am hopeful it makes a difference. I will give it a valid chance. Changing my oil every 3500 miles will remain my constant.
    Are you going to try it?
    PriFi and Mendel Leisk like this.
  11. Frankusa94
    Frankusa94 Junior Member
    60
    Ma
    First run of vavoline protect and restore is coming up… supposed to run 4 consecutive oil changes to achieve advertised results. $28 for 5quart jug, + $4 oil filter = $32 oil changes… worth the try… will post observations…
    Frank
    PriFi and Brian Adcock like this.
