Variability in Prius Steering
Discussion in 'Gen 3 Prius Main Forum' started by tbird86ghz, Feb 1, 2012.
  1. tbird86ghz
    tbird86ghz New Member
    SoCal
    Hi team,
    Thanks for all the information thus far; I'm now the proud owner of a new 2011 Prius II! (If you're looking in SoCal, PM me and I'll fwd details). I drove it off the lot yesterday with 10 miles on it. A question though for those with experience driving these - something about the car seems a bit "off" when it comes to steering - the car seems to wobble a bit around 50mph+, and when I compare the steering to a friend's 2010 Prius III mine definitely strikes me as a lot "looser." Is this to be expected as natural differences from car-to-car, a break-in period, or something I should be concerned about to take back to the dealer? Thoughts?
  2. tevogel
    tevogel Junior Member
    40
    slater,mo.
    2015 Prius Alpha
    take it back!!
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Yeah, if it happens all the time at highway speeds just take the car back to the dealer for them to look at and see for themselves. Surely it shouldn't be wobbling at 50mph.
  4. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    Ditto - don't fool around - have it checked immediately.
  5. tbird86ghz
    SoCal
    yikes, back to the dealer I go then. thanks!
  6. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Have you checked the tire pressure? I've noticed small differences in steering feel at times, depending on the tire pressure.
    The Prius' EPS also seems to provide different feel at times, not sure why.
  7. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I have a 2011 II no issue at all. The steering wheel is solid at any speed limit.
    Are those stock tires? Tire could be out of round? Has the car sat on the lot long?
    If different then look into how they were mounted. Maybe lost rim weight.
    Dealer might rotate the tires around and see if that helps. Check for a bent rim.
    Mark each tire with a pen for a base line and have them find which one is the problem.
    If the tires are stock and rotating them around does not help then maybe axles.
    Does it stop the wobble when at 50mph-ish you remove your foot off the gas pedal, coasting around 50mph? Then axles, maybe?
    my2cents.
