vBulletin code for tables
Discussion in 'PriusChat Website Questions' started by JimboK, Jul 10, 2008.
  1. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    For those of use that occasionally like to post data in tabular form, is there any way the vBulletin code for tables can be enabled? I know it exists; CleanMPG has it enabled. It's a little cumbersome to use -- here's a sample:
    Column 1 Column 2 Column 3 Column 4 Column 5
    0 Heading Column 1 Column 2 Column 3
    1 Row 1 Data 1 Data 2 Data 3
    2 Row 2 Data 4 Data 5 Data 6
    3 Row 3 Data 7 Data 8 Data 9
    But it produces a very clean looking table (with boldfacing and underlining added for "Heading"):
    I wouldn't mind spending a little extra time to create a table if it helps the reader see the data.
  2. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Do you mean like this?
    head col1 head col2 head col3
    1 row1 col1 row1 col2 row1 col3
    2 row2 col1 row2 col2 row2 col3
    Thanks for making me take the time to look for this addition - it should be very helpful!
  3. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    So Exactly How
    1 does this new
    2 fangled thing work
    3 and just what
    4 is it good
    5 for :confused: ;)
  4. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Here's some info on how to use it. I haven't had much time to play around with it, so I can't translate this into English right now:
    Introduction to options:
    example:
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6 Column 7 Column 8
    0 The whole option list should be wrapped with quotes.
    1 Options are seperated by a semicolon
    2 If an option has a value it is assigned with "equal to" mark. (option2)
    3 If the value contains blanks or special characters it has to be wrapped with apostrophes. (option3)
    4 If an option has more than one value they are seperated by a comma. (option4)
    6 Description of options:
    7 head
    8 This option defines the first line as head so the first row is shown as head of the table. If the table sould be sorted the head is not sorted.
    10 sort=1d 2 3[/I]
    11 This defines the table to be sorted by column 1 then column 2 then column 3. The "d" after the first colum specifies the order: descending (default: ascending)
    13 autonum=1 (equal to autonum) autonum=a autonum=A
    14 Defines that a new first column containing a numbering should be inserted.
    15 1 -> 1 2 3 4 ... 999 1000 ....
    16 a -> a b c ... aa ab ... zz
    17 A -> A B C ... AA BB ... ZZ
    19 autonumtitle=oneword autonumtitle='long value with spaces'
    20 Defines the title of the autonum-column. Can be left empty.
    22 width=123px width=45em width=67%
    23 Defines the width of the table.
  5. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Woo-hoo! Thanks for the quick action!!! :first:
    I've already put it to work.
  6. Karado58
    Karado58 Junior Member
    Hi Danny,
    I placed this code in a post in my forum, but all i got was the code and no table.
    Can you please help?
    Thanks.
    Joseph
    vBulletin® Version 3.7.2
  7. talonts
    talonts VFAQman
    468
    76
    I'm still not seeing how to do columns in a table in a thread post. vBulletin says to separate by "|"s, but when I do so, anything after the first one on a row disappears. I've been Googling how to set up a table in a post, but no clear examples of the formatting have shown up.
    I can build tables easily enough in HTML, but vB is annoying me...
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Exactly the same problem here. Any update or tutorial for dummies? Thanks!
  9. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi 2009Prius,
    All your columns must be separate by "|" and every row should have the same no. of "|". Is this how you want your table to look like?
    0 12V battery check
    IG ​
    DMM SGII PriiDash
    2 [/LEFT]
    3 OFF 12.50 12.4 ---[/LEFT]
    Vincent
  10. 2009Prius
    2,705
    512
    63
    Thanks! How is the title done? Mine doesn't seem to show.
  11. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    Looks like you have to put it in Bold.
  12. vincent1449p
    894
    332
    Singapore
    You have to use the head option, your 1st row will be your header. It need not be in Bold, just my personal preference.
    e.g.
    12V battery check
    2 Vincent
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    sample
    0 heading A B C D[/b]
    1 Row 1 a b c d
    2 Row 2 e f g h
    3 Row 3 i j k l
  15. dolj
    dolj Senior Member
    8,581
    4,357
    Wellington, New Zealand
    No questions on tables in 6 years – y'all must be more smarter than me. lol
    Would any gurus still watching this thread have any suggestions.
    I'm trying to add text that contains commas within into a table cell, but the commas are being interpreted as delimiters ever though I am using "|" as a delimiter which it also recognises. I thought I had successfully done this on the past by enclosing the text with quotes, but this does not work – the quotes are rendered in the cell.
    So, the question is how is it done, or can it not be done.
    Example:
    using this code:
    Code:
    [TABLE=HEAD]CASE|[Left]ACTION[/LEFT]
    Case 1|"When out hiking, and you only have a day pack, be sure to check the weather."[/TABLE]
    The result is:
    CASE
    ACTION​
    1 Case 1 "When out hiking and you only have a day pack be sure to check the weather."
    Any and all input gratefully received.
    PS: I have tried many suggestions from BBCode sources as well as help on the XenForo website as well as here in this forum. A lot of the tags such as [TR] and [TD] but, it seems these are not implemented on this site. :(
    PPS: Also didn't find any help in this thread: BB Codes. It did not even mention tables. :(:(
    #16 dolj, May 2, 2018
  16. Tideland Prius
    16,626
    I don't know either and it has bugged me. I've also searched to no avail :(
  17. Oniki
    Oniki Active Member
    652
    499
    Colorado
    BB Code has a tag
    Code:
    [nobbc]  [/nobbc]
    that I think acts as a code parser escape but I presume @Danny has to enable its use.
    #18 Oniki, May 7, 2018
    Tideland Prius likes this.
  18. dolj
    dolj Senior Member
    8,581
    4,357
    Thanks for the suggestion, but it appears it is not implemented.
    I used this code:
    Code:
    Case 1|[nobbc]When out hiking, and you only have a day pack, be sure to check the weather.[/nobbc][/TABLE]
    Which gave this result:
    CASE
    ACTION​
    1 Case 1 [nobbc]When out hiking and you only have a day pack be sure to check the weather.[/nobbc]
    It seems there are a lot of bb-code tags that are not implemented in the add-on that @Danny uses.
    In Help>BB-Code it suggests the tags
    Code:
    [PLAIN][/PLAIN]
    Using this tag works both inside and outside the table, provided there are no commas.
    Code:
    [PLAIN]This is not [B]bold[/B] text.[/PLAIN]
    renders as:
    When used in a table, this code
    Code:
    Case 1|[PLAIN]When out hiking, and you only have a day pack, be sure to check the weather.[/PLAIN]
    Case 2|[PLAIN]This is not [B]bold[/B] text.[/PLAIN][/TABLE]
    renders as:
    CASE
    ACTION​
    1 Case 1 When out hiking and you only have a day pack be sure to check the weather.[/PLAIN]
    2 Case 2 This is not [B]bold[/B] text.
    It seems like an error in parsing the within the table add-on, maybe, because in Case 1 it seems like the PLAIN tag is terminated by the comma in the text, but Case 2 parses correctly.
    If I add a comma to Case 2, it breaks it:
    Code:
    Case 2|[PLAIN]This, is not [B]bold[/B] text.[/PLAIN][/TABLE]
    it renders as:
    CASE
    ACTION​
    2 Case 2 This is not bold text.[/PLAIN]
    Hmmm.
    I guess we keep looking.
    #19 dolj, May 12, 2018
  19. UggaDugga
    UggaDugga Junior Member
    Stoughton, WI
    So there's really no easier way to post info in a table than by learning to use the code for posting? :eek:
