Vegas Heat mpg issues?
Discussion in 'Gen 4 Prius Fuel Economy' started by VegasJeff, Jun 10, 2016.
  1. VegasJeff
    VegasJeff Junior Member
    Las Vegas
    Have not purchased a Prius yet as I have a TDI awaiting results of the lawsuit. I am wondering over the last week or so, Vegas has been really hot. Just wondering how the new battery and the MPG is holding up in the Vegas heat.
    Thanks for any feedback
  2. wjtracy
    wjtracy Senior Member
    11,335
    3,596
    Northern VA (NoVA)
    As far as battery health, if its anything like Gen2 or 3, we'll know in about 7 years. No reports of failures to date, nor would we expect any yet. MPG is normally favored by heat so not expecting issue there either.
    Some people give a new model a year or two to allow any refinements. IN this case, I don't think you have to, but if you wanted to you could.
  3. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    One way of reducing 'pumping' losses in an engine is to have the throttle more open more often. (As you know the throttle is ALWAYS open in a diesel, so they removed it) The less dense air in hot weather has the throttle open wider to pull in the same number of oxygen molecules, so hot air favors engine efficiency. The downside is that A/C runs more to cool both the driver and the battery. Long trips with A/C are more efficient than short trips with A/C.
    Battery Chemistrys vary in the effects of temperature, Wikipedia says "Lithium-ion chemistry performs well at elevated temperatures but prolonged exposure to heat reduces battery life." So storing your car in shade may be more important than driving your car in heat. Had you lived in Ely, NV the winter cold temps would be more a concern than Las Vegas's summer heat.
    Should you buy a Prius in NV, it has a 8 year, 100,000 mile battery warranty, which is not pro rated.
    Coast Cruiser likes this.
  4. Mendel Leisk
    39,015
    High ambient temps raise the battery temp. Worst is parking in direct sun I think. Underground parking helps.
  5. VegasJeff
    Las Vegas
    I had a feeling it is way too early to tell. I do keep my car garaged at night but don't have that luxury at work.
    8 years is a long time and I would have about 130k miles on it. The issue I have is the cost to replace the battery.
    3-4k is a huge bill for a battery on a 8+year car
  6. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    OK lets look at the idea. Would you buy a new engine for an 8+ year old car? New Transmission? NO, you would get a rebuilt or a 'pull' from a junk yard.
    Same for a HV Battery, many more Prius are wrecked than wear out the battery, so on ebay you can get one pretty cheap. $800 to $1500 (Most totaled cars are from front end damage, leaving the battery unaffected)
    Toyota Prius 2008 in Other | eBay
    Not all of these fit a 2008 (a 2008 would be 8 years old today, so in 8 years your 2016 battery would be as common)
    While heat is a concern, mountains seem to cause the heat IN the battery, not climate itself.
    #6 JimboPalmer, Jun 11, 2016
  7. CR94
    CR94 Senior Member
    2,642
    1,140
    Northwestern S.C.
    That's a good reason not to be too reluctant to use "B" on major descents, especially when the battery is already warm.
    bwilson4web likes this.
  8. Mendel Leisk
    39,015
    Even driving in "ideal" conditions, near-level highway with 80 kmh limit, cool evening, I see battery temps around 35C.
  9. pakitt
    pakitt Senior Member
    2,173
    1,312
    Colorado
    How much would a clutch replacement or engine chain cost?
    How much would a double clutch replacement cost (like on some modern VW and similar cars with "automated" gear shift)?
  10. VegasJeff
    Las Vegas
    I agree, VW's are expensive to fix and I had many issues with my TDI, luckily all under warranty. Don't forget about the DPF sending shards into the engine, heard that is about a 7-8k repair.
    Still waiting for the news to become real. It is looking good though for a buyback.
    snipercoder likes this.
  11. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    HPFP, not DPF. Hope you get cash and not a credit to buy another VW.
  12. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Florida heat seems to not effect battery life so far. Make sure the battery cooling vents are not blocked.
  13. JimmyPri
    JimmyPri Active Member
    201
    243
    Hilo, Hawaii
    What would you say is a safe high ambient temperature range for the inside of the 2016 Prius to get before over time it will adversly affect the lithium ion battery?
  14. snipercoder
    snipercoder Member
    76
    40
    CA
    Three Touring
    What kind of issues did you have with the TDI? Any carbon build up at 40k-60k miles? I was considering buying a TDI before the scandal broke back in September. I'm hoping the HV battery would last more than 10 years, anything less than that would NOT be ok in my book.
  15. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    No prius had a li-ion battery before 2016 except the plug in, which i do not think was sold in NV.
  16. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    The battery is low and under , and it draws it's air from the passenger compartment.
    I think that high temperature air that could hurt the battery would probably kill the passengers first.
    krmcg likes this.
  17. VegasJeff
    Las Vegas
    I only have 32k on the car. I had a lot of small issues with the car but nothing engine related. The biggest issue was a growling noise that only happened when the A/C was off. Once the A/C was on, the noise went away. I recorded the noise several times and took it to the dealer. Both dealer and VWoA said it was normal. Finally took it to another shop who just replaced the compressor and really wasn't worried about the fight with VW. The fix happened to work.
    I have gotten 3 recall notices in the last month. All 3 said they couldn't fix it as of yet and to wait until I receive another notice of repair.
  18. bwilson4web
    15,603
    Uh "VW" ????
  19. jbkendrick
    jbkendrick Active Member
    232
    197
    Baltimore, MD
    Decision has been announced and just waiting for public comment period which ends later this month, and then judge will sign off. Buy back is for clean trade value as of 9/2015 plus cash which varies according to age of vehicle, minimum of $5,000. Payouts not expected to begin until October 2016. I went ahead and parked my TDI and am enjoying my new Prius 4. J
    Jim in NC, eric1234 and bwilson4web like this.
  20. Prius Pete
    Prius Pete Active Member
    183
    178
    Toronto
    People always worry about replacing the hybrid battery but it is very rare. Look at longtermqualityindex.com which has statistics for power train problems in over 1 M US trade-ins. The Prius has fewer problems than any other compact car, and that includes hybrid battery problems. You are much much more likely to have expensive transmission or engine problems in a VW/Audi -- most of their models have below average long term reliability. My 2004 Prius is going strong on its original hybrid battery with 182,000 miles now.
    #20 Prius Pete, Jul 19, 2016
    Jim in NC likes this.
