Vehicle Maintenance
Discussion in 'Gen 3 Prius Main Forum' started by Raj gowri, Sep 11, 2019.
  1. Raj gowri
    Raj gowri Junior Member
    New Zealand
    team,
    My prius Gen3 2011 has done 300,000 kms. Runs good. Will just the oil change, air filter and keeping the fluids topped up is good enough or does it need any special attention? I dont have the service Manual.
  2. Tideland Prius
    16,142
    Here's the NZ schedule.
    https://www.toyota.co.nz/globalassets/servicing/toyota-petrol-hybrid-service-schedule-2019.pdf
    After 195,000km, you start again from the top. (So you'd be at the "year 7/105,000" row. Your next service is the next row - 8/120,000 or in 15,000km - O&F as well as replace brake fluid.
    The coolant should've been just replaced at 300,000km (Coolant is every 75,000km after the first D at 150,000km). It doesn't specify so I'd change both engine and inverter coolant at the same time.
    49,430
    have you done all the scheduled maintenance up to this point?
  4. GFO
    GFO Member
    67
    47
    Larkspur
    300K kms is about 186K miles, it sounds like the EGR has never been serviced/cleaned and the car still runs great.
    Would really like love to know what exact conditions make it so some 3rd gens blow head-gaskets and some don't due to the EGR clogging.
    Gut instinct tells me it's a combo of the type of oil used and driving habits, making some cars burn more oil than others, and the EGR failing stemming from carbonized oil particles clogging up the system. Thoughts here anyone?
    My car only uses about 1/2 a quart every 4-5K miles, 65,xxx on the odometer.
  5. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    I agree.
    Mine is consuming less than half that much, I think, at 102k. Wondering whether it will suddenly get much worse keeps me in suspense.
  6. GFO
    GFO Member
    67
    47
    Larkspur
    Really should have said 'oil change intervals', oil brand doesn't matter a whole lot these days and it's probably safe to assume everyone is using a API rated 0w-20 or 5w-30 synthetic.
  7. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Unless the jiffy lube or Walmart car oil technician grabs the conventional oil hose dispenser and dumps it in your crankcase, then put a checkmark next to synthetic oil 0w-20 change.
    SpEaking from others experience.
    #7 Grit, Sep 13, 2019
    Jon Watkins likes this.
  8. GFO
    GFO Member
    67
    47
    Larkspur
    Fair enough comment, especially considering how shady the 10min change places can be. Didn't consider that.
