Vehicle Moves with electric motor. Not under ICE video
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mypriuscious, Mar 18, 2023.
  1. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    So, I'm driving along last night and I press on the accelerator and the vehicle goes forward until ICE kicks in and then a horrible sound is present while running and vibration coming through the floor. I pull over to a side road. Shut it down. It will still turn over the engine, hence how I was able to make the video. It will move forward on electric power but not ICE. Engine is smooth while running.
    49,492
    howmany miles on her?
    any trouble lights?
    could be a lot of things
  3. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    Check engine light. But my scanner with torque app didn't pick anything up. The transmission has unknown miles as it was recently (dec) replaced with a JDM 55k mile engine. I had got one last April with 135 but that one was allegedly bad and it was a whole thing trying to make sure that it was bad, but when replaced the car ran and drove perfectly until now.
    49,492
    most likely the recent work, but you apprently need a better reader. there have to be codes
  5. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    What would you suggest?
  6. bisco
    49,492
    tech stream is the gold standard, but you can find others in the tech section here with a search
  7. Mendel Leisk
    38,727
    Spring for a dealership diagnostic; confirm up-front they’ll print out the codes?
  8. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    Update: Went to the mechanics to look at it and when it first turned on engine running it didn't make any extra noise. About 30 secs in it started making the noise. I was able to drive it under gas power and the noise was slightly intermittent. I didn't go over 22 mph tops.
    Edit: No codes relevant to engine or transmission on a much better scanner.
  9. bisco
    49,492
    yeah, no. most mechs scanners won't work on a prius unfortunately. i guarantee you, if there's a light, there's a code.
    without them, we're shooting in the dark
    mypriuscious likes this.
  10. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    I know right. It's one of the higher level Autel scanner. And it picked up and read all the codes. But it def doesn't help with hybrid system codes. My bluetooth scanner was the one who couldn't pick up all the codes.
  11. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    Update: a motor mount or transmission either broke or came loose. Was replaced and fixed the issue.
    fotomoto likes this.
  12. ASRDogman
    ASRDogman Senior Member
    6,092
    3,273
    ??? A motor/transmission mount kept the engine from starting???
  13. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    The engine would always start, as shown in the video. However, it would not move when the ICE would turn on. It would vibrate heavily and behave sluggishly.
