Vehicle Stabilty Beep and Red Triangle Warning Coming On
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jared, Apr 12, 2015.
  1. Jared
    Jared Member
    209
    Long Island
    My 2010 Prius (130k miles) has recently started beeping on curves, turns and braking on occasion. The red triangle also comes on. There is no problem otherwise. It is a bit annoying. Anyone have any ideas as to the cause of this? Could I have the beep turned off? Thanks.
  2. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Sounds like aggressive driving on worn tires to me. Anything that makes a tire lose traction will cause this like wet streets, loose gravel, potholes, etc.
    Bill the Engineer
  3. Jared
    Jared Member
    209
    Long Island
    Thanks,
    The tires are a bit worn but not worn out.
    I do drive pretty fast and always in power mode.
    49,469
    it's a safety feature, so can't be turned off. slow down.:p
  5. Patrick Wong
    18,200
    6,474
    What is the tire tread depth? If less than 4/32" you should replace them given your driving habits and your concern about the VSC system triggering as a result of those habits.
  6. Jared
    Jared Member
    209
    Long Island
    I don't think it is the tires or my driving. The car just passed the safety today and my driving is no different from before. I think it may need a zero recalibration of the VSC system. Anyone know more about this? Thanks.
