Vent in back seat and check engine lights?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 58teeth, Apr 25, 2019.
  1. 58teeth
    58teeth Junior Member
    CO
    Hey folks!
    Have a 2008 Prius w/ 175k on it. All original. This morning, the red triangle came on, as well as the (!) and VSC errors. The engine feels a little labored and doesn't sound the way it usually does. Also, for the first time ever, I heard air rushing out of the vent on the passenger side in the rear. A quick OBD Code read showed P0080.
    Any thoughts? I'm bringing it in tomorrow to the mechanic, but want to be prepared in case they tell me I need a new $5k part if I don't.
    Thanks
  2. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    Don’t laugh but check to make sure your gas cap is tightened. 1 click.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    A couple things.
    First, was it a quick OBDII read with a reader that reads Prius codes? If not, it's quite likely not the right code.
    Second, you scared the crappola out of me!! Prius Primes shouldn't be throwing codes yet. :LOL: Most of us with Primes have Gen 2 experience, but I'd suggest clicking the "report" link under your signature line and asking a moderator to move this to the Gen 2 forums so the Gen 2 wizards are more likely to see it and be able to advise.
    Be sure to take it to a hybrid mechanic. He should give you the correct codes and diagnosis. Let us know what happens. And good luck! (y)
    jb in NE likes this.
    49,399
    probably you're hybrid battery. check in with @2k1Toaster , he's in your neighborhood and has a new aftermarket replacement for $1,600. plus labor.
    58teeth likes this.
  5. 58teeth
    CO
    Thanks I reported it to be moved. Sorry about that!!
  6. 58teeth
    CO
    I accidentally cleared the reader code (squeezed the reset button while climbing out from the dash), does the onboard computer save code history?
  7. bisco
    49,399
    they might be gone, but a short drive should reinstate them.
    58teeth likes this.
  8. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    P0A80 + being able to hear the HV battery fan = near certainty that your HV Battery is dying.
    Replace ASAP.
    2k1Toaster's cylindrical cells are a good option, if you can't get a local dealer to sell to you for under $1800. You will have to make phone calls to see if a local dealer will sell to you and match another dealer's lower price for the HV Battery. No dealer will ship the HV battery b/c the cost is exorbitant.
    See post#11 to get an idea of OEM HV Battery pricing; granted this was in Nov 2018.
    Indianapolis area battery repair? | PriusChat
  9. jerrymildred
    11,508
    14,109
    Tampa, FL
    No worries. It happens a lot. (y) Just want to make sure you get this figured out asap.
    Lots of codes get kept in history. If the technician is using Techstream, it'll find them.
    SFO likes this.
