Venting humidity from the cabin
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Mileage_Mofo, May 3, 2019.
  1. Mileage_Mofo
    Mileage_Mofo New Member
    16
    I'm looking for a way to vent the humidity with the windows up while camping in the car at night.
    I was thinking of trying to vent it through the dash vents, but I'm not sure if that's a viable option.
    SFO likes this.
    52,390
    are you running a/c?
    WilDavis likes this.
  3. Mileage_Mofo
    16
    No, most nights without a/c
    52,390
    if you're not running the engine or hvac, you would need a fan set up to the battery vent or cracked window. not sure how effective it would be though.
  5. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    On our cross country trips I carry a rechargeable jump starter along with a portable air compressor in case of emergency. It also can be used to power other things. How about getting a small, portable dehumidifier and powering it all night from that? That way it won't tax the car's systems.
  6. Mileage_Mofo
    16
    That's a good idea, I'll look around for a battery powered dehumidifier
  7. landspeed
    landspeed Active Member
    387
    209
    NZ
    2003 Prius
    Did you find a dehumidifier? Most use a compressor so actually use a lot of power and will drain the 12v battery very quickly.
    However you can run the fans built in to the car with the car off, using this info:
    Prius camping
    I like this mod, and need to look into how to run it off an external 12v (alternatively, get a new 12v if yours is worn and carry a jump pack just in case. I have jumped my car from a tiny 7ah 12v house alarm battery before so even one of those, kept charged, could be a good emergency jump pack!
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    But it will tax the hell out of the portable battery.
    Any real dehumidifier will draw WAY too much power for that to work.
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    If you blow the humid air OUT, you must have an opening to draw fresh air IN.
    Maybe the vent ducts would do that; don't know.
    Search for a cheap "solar powered" window mounted car vent that runs on 12 V.
    That should have a low enough draw that it would run for a long time on a portable battery.
    landspeed likes this.
  10. srellim234
    1,201
    1,694
    Laughlin, Nevada
  11. landspeed
    387
    209
    NZ
    2003 Prius
    The car has vents in the rear - hidden behind the plastic covers and behind the bumper; if you use hobbit’s circuit in the link above, it will keep air flowing constantly from the front to the back.
  12. Marcilla Smith
    Marcilla Smith Active Member
    140
    124
    Raleigh, NC
    For what reason would someone avoid running the A/C?
  13. ChapmanF
    18,546
    The built-in A/C will convert the humidity to condensed water, and vent the water out a drain tube through the floor.
  14. Marcilla Smith
    140
    124
    Raleigh, NC
    Did I miss something? What would be the problem with water draining onto the ground?
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    Apparently you did.
    I didn't see him say, imply or hint at that being a problem.
  16. Marcilla Smith
    140
    124
    Raleigh, NC
    Perhaps I read too much into someone posting immediately after "For what reason would someone avoid running the A/C?" with "The built-in A/C will... vent the water out a drain tube through the floor"
  17. bisco
    52,390
    the thread got messed up after you post #12. chap wasn't replying to you, he was letting the o/p know what a/c would do.
    o/p didn't say he didn't want to run a/c, he said most nights, he wasn't running a/c.
    Marcilla Smith likes this.
  18. Marcilla Smith
    140
    124
    Raleigh, NC
    Ok.
    I'm still wondering what is the purpose of building a Rube Goldberg device to avoid turning on the AC, but I'm just a dumb woman, so what can be expected?
    jb in NE and bisco like this.
  19. bisco
    52,390
    it's probably too cool to run the a/c
  20. ChapmanF
    18,546
    I'm pretty square and I run the A/C routinely
